CA hand clutch brake drum rebuild
timo2le View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timo2le Quote  Post ReplyReply Direct Link To This Post Topic: CA hand clutch brake drum rebuild
    Posted: 01 Jun 2012 at 5:27am
Hello,
I'm preparing to rework the right axle of a CA.  I have parts ordered from Sandy Lake and Chris/CT.  I ordered a left side brake drum to verify the "original" diameter as a reference to rebuilding the left side drum.  I believe the diameter spec. is 5.990".
For those of you that have installed (or had a Machine shop do it) a sleeve over the right side drum, do you know what material (steel or cast iron) was used to create the sleeve?   My drum diameter is 5.700.  After I turn the drum to get 80 -100%, "clean-up", I will be installing a sleeve with ≈.160" wall thickness.  I would like the sleeve to be cast iron (like the original drum) but making it from steel pipe or bar will be a whole lot easier and I won't have concern about the sleeve "splitting".  Comments from those who have rebuilt their CA brake drum will be appreciated.
Thanks,
Tim in Wisconsin.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 7:05am
How do you plan on keeping the sleeve tight on the drum? When the brakes are applied the sleeve will get hot and expand, you must be planning on a real tight fit I have never heard of this done but am curious.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 7:26pm
Been there- done that. My machinist mage a sleeve from pipe; it needed to be heated like a ring gear to slip on. When on, he spot welded it in a few spots "just to be sure". Worked great.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 7:47pm
Tim, Your parts were shipped this morning, you should see on Monday. I agree with Greg on remedie for the sleeve install. Some have suggested to grind a slight amount of the 3 stand that compress the springs, I'm sure you have seen this suggestion on previous posts.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 9:21pm
Can't ypu just screw a band of steel on top of the drum?
Just drill a hole and countersink a flat head machine screw. Either tap the drum or put a nut on the inside. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote timo2le Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 5:07am
Thanks Greg & Chris.  The "ring gear" is a great example of a shrink fit with good resistance to slipping.  I would have liked ductile iron for the wear characteristics, but I will be starting with 6" SCH 160 steel pipe also.  A couple "safety" welds will be icing on the cake!
Bob, I had also pictured rolling a ring, and attaching with countersunk screws.  I think that would work OK since this CA isn't going to the Daytona 500 but since I'm surrounded by a bunch of good machinists I'll have the parts machined/shrink fit.
I brought in my clutch disks this morning so we can face them on a rotary (Blanchard) grinder.
It's gonna feel so good to have brakes that can pivot the tractor, and clutch that climb a hill!!
Have a good weekend!
Tim
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 10:39am
 I had mine spray welded then turned down to size. That seemed pretty strait, simple, and forward.
Thanks & God Bless
Dennis
