Rotary Mower on a B |
Post Reply ![]() |
rrambo ![]() Silver Level ![]() Joined: 30 Apr 2012 Location: GA Points: 56 |
![]() ![]() ![]() ![]() ![]() Posted: 30 May 2012 at 1:43pm |
How big of a rotary mower can a B comfortably handle? I'm thinking 48" but was wondering if a 60" is too much?
I've seen my dad do some crazy things with his old 8n over the years so I know that these old tractors can/might handle more than they are rated for. I'm hopefully about to buy some land (crossing fingers) and it will need a lot of cleanup work.. mostly tall weeds, bushes, etc., and I'm looking for a used rotary mower to use behind my B once I get it running.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
It will handle a woods L59 or L306 without any problems. an L59 is 60 inches and a L306 is 72". I have a L306 on a C. has the same engine as a B and never have a problem. if your wanting a Brush cutter than down size. I'd still go with a 60" |
Thanks.. I need to do some heavy brush cutting.. that is if I even get this property I'm trying to buy.. about 10 acres of heavy weeds, small brush.
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
I would consider a 48" blade. Why, in not heavy work the B can handle 60" but in what you suggest you are doing I would stay with 48". Don't forget an overrunning clutch. With a mower with that big of a blade they can "push" the B. Take good care of my favorite. Good Luck! Bill Long |
Dean (West MI) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: West Michigan Points: 1282 |
My B runs a 3-point, 60" rotary mower, works great!
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6496 |
For heavy cutting a 48" with an over run clutch would be right for a B. Light cutting it will handle a 60" just fine.
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
we have sold more L306,S THAN L59,S if set up correct it will slip belt before pulling the engine my 2 cents since 1990
Post Reply ![]() |
