AC 7060 pto shaft question |
Post Reply ![]() |
AC 426 power ![]() Orange Level Access ![]() ![]() Joined: 01 May 2012 Location: Ohio Points: 525 |
![]() ![]() ![]() ![]() ![]() Posted: 29 May 2012 at 7:28pm |
I was hooking up my 535 baler and when i turned on the pto i noticed that there was an unusual wooble in the rotation and when i took it off to inspect i noticed that two of the bolts that hold the reversible 540/1000 shaft where broke off and the others where lose so i replaced the broken ones and Tietend the others but it still had a wooble. is the shaft it self bent ? I inspected it but i really cant tell. Or is there a more serious internal problem ?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21836 |
If it isn't leaking oil, there's probably nothing wrong......other than a bent 540 shaft.
Thanks i appreciate the reply
Post Reply ![]() |
