D 21 tractor not moving?
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Topic: D 21 tractor not moving?
    Posted: 27 May 2012 at 5:40pm
I am looking at a D21. The vendor was straight up and said that he bought the tractor last year to resell, it runs good in his opinion, but, he also said he drove it in all gears last year and it was fine. He also pulled a disc with it to make sure it pulled under load. Says he pulls something with all his tractors for resale to make sure they function.This guy buys and sells tractors mostly for restoration and smaller farmers. He has a good reputation, and is actually distantly related to me we found out after talking. He said he is aggravated that this spring after the tractor sat inside for the winter, he started it up no problem, put it in gear and it won't move. He tried all gears and both ranges. He said ther is no noise of any kind from the trans or diffy. He really doesnt want to sel me the tractor and is not sure what he is going to do with it. He says there is no money left for him once he starts pulling tractors apart. He also said its far to nice to part out, and couldnt bear to do that. My question is what causes a D 21 to move fine upon storage and then...not? I have several ideas but want to hear from members here. Sorry for the long post but this tractor would be a silly dream come true for this country boy living in the City, thanks, Trev.
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 5:44pm
Not knowing the whole story or being there I would guess that the clutch is hung up on the splines in the dissengaged position. I have only seen one other one do that so it is a long shot but possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 5:53pm
With the clutch pedal "up", try and shift the 4-speed transmssion to see if there is any rotation or grinding.......then go on to the range lever and see what it does. I suppose the clutch disc could have the center ripped loose on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 6:12pm
I agree Dr that does happen and why it let loose there who knows but goofier things have happened.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 6:43pm
Went to pick up a D14 to do a clutch job roe a guy becuz it would not release -- when driveing it up on trailer something let go and then it would not move, what happened was the center came loose as the DR. said. At first a couple rivets came out that got bound up in the lining to flywhee area and then all the rest came out of the center and tractor would not move.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 7:17pm
So at a minimum, Im looking at splitting the tractor for a clutch in other words. How much is a clutch worth? And there may be other damage? Flywheel surfacing at the least?
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 4:30pm
On my 21 it worked fine in the fall , sat all winter and spring then when summer came and i had some time to play it would slip under a load. I ordered a new clutch and pressure plate so i'd be ready when i split the old gal and all i would need to do was get the flywheel turned. The shop freed up so i ran her in and split it, the disc had some wear but not that much for the way it was acting and there was some hot spots on the flywheel which i expected. Turned the flywheel put new seals and clutch and pressure plate in and slid it back together. When i tried adjusting the free travel there just was not enough travel of the parts. Split it again and began measuring everything. I was ready to chuck the throw out bearing holder in the lathe to gain some clearance when i realized how the bell crank clutch linkage worked. On top of the bellhousing there is a pocket that the linkage pivots in and I ended up chiseling and blowing out 45 years worth of dirt, acorns, grass, corn cobs, sticks and whatever elses critters had placed in there. After that i had a whole bunch of adjustment room, probably could have done that to start with and not spent hard earned dead presidents on new parts. long story short a few winter stored acorns by some ground squirrels could make you a deal on one of the best looking tractors A-c ever made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 8:06pm
Perry doesnt know Allis from a bag of weiners. I gotta go look at this thing, see whats going on. A pile of dirt and so on is a good possibility...Maybe a good cleaning and adjustment might help, thanks for the replies, Trev.
