Correct batteries for a 190 |
Post Reply ![]() |
2wise4agm ![]() Orange Level ![]() ![]() Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
![]() ![]() ![]() ![]() ![]() Posted: 23 May 2012 at 11:46am |
Can someone tell me what the correct size batteries are for a 190xt. My battery box currently has 2 car batteries with a bunch of wooden shims holding them tight. Thanks
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 42010 |
That works and the car batteries can be bought with 5 or 6 year warranty where tractor battery has at most 2 year and will cost more.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8360 |
I believe they are supposed to have 2 , 900 cca hooked on parelel
XT in pa ![]() Orange Level ![]() ![]() Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
i put two 1200cca in mine
Shawn |
190XT,D17and 7045
Jordan(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Celina, OH Points: 1567 |
Should be group 31.
Darb210 ![]() Orange Level ![]() ![]() Joined: 10 Jan 2011 Location: Ohio Points: 884 |
I use group 27
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
27 is standard and 31 were the heavy duty option if I remember right. I use 27. Either will work.
Wink I am a Russian Bot |
Thanks guys. I know that the car batteries will work too, I'm just kind of anal I guess. Just don't really like wooden shims and bungee cords holding my batteries down. Especially when the original hold down is there and in good shape.
Andy190xt ![]() Bronze Level ![]() Joined: 13 Oct 2017 Location: North Olmsted Points: 14 |
I can see that this thread is quite old but I was just wondering what size wire to run for the batteries? I am glad of any help
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Welding cables, Andy. Welding cables have a little bit smaller cross section than SEA wire sized cables, but they are more flexible. They work well. Have a truck repair shop build a set for you.
Edited by DougS - 13 Nov 2017 at 2:38pm |
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
I have 2 car batteries in mine. with wood between/under them. seem to last as long or longer than tractor batteries. and are cheaper
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5244 |
Group 31 from TSC, they are made by Exide battery co for TSC. $99 each. Do a great job so far but I have only had them a year.
REEDE ![]() Silver Level ![]() Joined: 24 Apr 2010 Points: 286 |
The old ALLIS CHALMERS part # was 243473 or BCI group size 30H for a 190XTD.
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9942 |
I have had Interstate batteries in my 180 diesel for years. Interstate just seem to do much better than other batteries.
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
Looked at Exide recently at a large chain "Farm & Ranch Store". Asked someone I knew had been at that store for some time how many came back? Was told they were under review and that chain was looking at going with other vendors due to failures/returns before hitting end of warranty.
I stayed with Continental as the last one was ten years old. They change-up designs/ratings constantly on batts it seems and many of the low end now seem to struggle with lasting the advertised warranty period. Subject to use and maintenance but Continentals have worked for me so far . . . .
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1504 |
Can you fit 2 truck batteries in there. They do a great job and are usually much cheaper than the automotive ones. Would have to check if the top stud arrangement works for you.
Post Reply ![]() |
