6080 AC no throttle response
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 6080 AC no throttle response
    Posted: 22 May 2012 at 6:13pm
My 6080,s actin up a little , you push the throttle handle up to open her up and nothing , you pull it down and push it up again and it works perfect ; what the h--- is going on ??
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 9:00pm
sticking metering valve. Probably time for pump freshening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 9:15pm
Is the linkage loose on back side of pump?   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 3:40am
Yes its all loose
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 5:13am
unhook the linkage at the pump and see if it does the same thing by hand
before you go to tearing off the pump
sounds like it could be a loose andslipping cable to me
i like old tractors of all colors
This page was generated in 0.079 seconds.
