getting bolt out
Tim in arkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in arkansas Quote  Post ReplyReply Direct Link To This Post Topic: getting bolt out
    Posted: 19 May 2012 at 8:28pm
 I been working on my 1940 model B  and I have trouble  I got one bolt that holds the steering box to the tube  the other bolt the threads are stripped  and will not turn I have tried everything  so can I cut the bolt off and drill a hole and use an easy out to do the trick?  thanks Confused
Allis Chalmers fan from Arkansas
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 8:32pm
If the bolt is siezed in the hole I'd say drilling and easy out won't work very good. If you can get a little heat on the outside of the bolt without cooking anything it'll likely come out.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in arkansas Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 8:34pm
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 8:34pm
Cut the head off , leave the bolt sticking up , weld a large nut to the bolt shank then wrench it out
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:28pm
welder
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 6:33am
I did a 'modified' version of Coke's method.
I put a washer on first THEN weld a nut onto the busted bolt shaft.
Let it totally cool BEFORE you try to undo !!!
The washer gave me some wiggle room with the AC stick welder and my 'nervous' handiwork !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 6:51am
After welding, wait till things aren't cherry red and start wrenching.  I never wait till it cools all the way down. Heat is one of your friendly tools in a situation like stuck bolts.
Edited by CTuckerNWIL - 20 May 2012 at 6:51am
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 8:35am
If the bolt is big enough, I drill the center of the bolt with a 1/3 size drill bit, then reweld the drill hole with qw wire welder, then weld a washer on. As it is cooling down, apply a candle to the threads. Then you can take out with a pair of pliers.
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 8:45am
If that fails, drill and tap new treads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 8:53am
that wax method works well , a candle or even a old color crayon applied along side the hot bolt, allows the wax to seep down into spaces and lube the rusty threads.
