The new rig
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: The new rig
    Posted: 17 May 2012 at 10:34pm
Did my first big mowing job with the new Bush Hog 3008 and I have to say I like it.  It is really quiet and cuts better than the JD MX8 that it replaced. It is shorter than the JD so the rig fits on my trailer better, also. Only thing I don't like is it is hard to grease the pto U-joints.....Oh, and the 175D did fine too...
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 10:42pm
Mower looks beefy with those 3 big gear boxs and thick steel. American made?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 10:53pm
They are made in Alabama, not sure if the gearboxes are American made....I haven't looked for a stamp.  I know the JD boxes say "made in Spain" on them.  I will check when I get a chance...I know they are quite a bit bigger than the JD ones....
ALLIS EXPRESS!
This year:
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 7:24am
Should think that will get 'er done!
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 8:10am
Can you take a picture of the bottom side?   Just wondering how they run the blade system on those.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 8:38am
Eldon, In my opinion these are superior machines.I've had 3 competitors and they are not even in the same ballpark. The gearboxes are bulletproof.I would keep up with the SN # because the PTO shafts are made by 2or3 different companys and they (Bush Hog)don't always use the same supplier.Find out what yours is and make note of it now and it will save you a headach when you need u joints later. My 2615 uses Comer . Scott
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 11:15am
It does look a lot heaver built then the JD, closer to the right color too!
Allis Express participant
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 12:20pm
I have to jump in here and stand up for the Bush Hog too....cause I welded 'em together over 30 years ago before I went to the seminary... the little 5 footer was maybe a weak point but the bigger ones were heave metal...
and the dish that the blades were mounted to was the "stump jumper" ...after the end of the blade cut of the tree you would not get caught up on the stump.
peace
AllisUpstate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 1:07pm
Eldon,
Is that an 8 footer?  I'm curious how the 175 handles the weight.  I wound up finding a 7 ft flail that comes in at about 900 lbs, and the D17IV is a bit light on the front without extra weight.  Your Bush Hog looks to be quite a bit heavier.  Nice looking mower and tractor for sure!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 3:30pm
Originally posted by AllisUpstate AllisUpstate wrote:
Eldon,
Yes it is an 8 ft and weighs right around 1900#. It takes the full rack of front weights and the front tires are also full of fluid. With new brakes  and all that weight the 175 turns on a dime....
I put the JD on the Series IV diesel without front weights and it will lift the front end off the ground just letting out the clutch.
ALLIS EXPRESS!
This year:
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 4:07pm
How much H.P. is required for the 3008?  nice lookin outfit!!
JeffMOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 5:33pm
Bush hog 3008 requires 40hp to run and 50hp to lift.
Here is a link to the specs.
http://www.opico.com/files/Bush%20Hog%20Multi%20Spindle%20Mower%20RC3008.pdf
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 8:16pm
Awesome hog Eldon and awesome tractor too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 9:00pm
I put a 3008 with a mulching kit behind the 180, front end got a little light so I added a loader for ballast, be real careful with that 1800# when on grades with any fast manuevers; had it four years now and no complaints.
