190 trans oil going to axle housing
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Topic: 190 trans oil going to axle housing
    Posted: 15 May 2012 at 9:02pm
On my 190 the trans oil is filling the right axle housing causing the outside axle seal to leak and not keeping trans full. Was told its the axle cap can get to it by removing the pto housing (two speed pto) Any tips tricks or things to look for when I'm in there? Just replace the cap with some kind of sealer to keep it in place?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2012 at 9:17pm
Thats what i done, not much to see other than the ring and pinion
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2012 at 9:22pm
Did you just replace the cap? and good to go. Wonder what makes them come out? old age mine has around 7000 hours. My tires are worn and when I'm empty on a hard dirt road in 7 or 8 gear I do geat a vibration, wonder if that would shake it loose?
Edited by DanWi - 15 May 2012 at 9:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 4:15am
Mine vibrates too in road gear, most do, if the cap looks good i just used silicone and glued it back, if it fits real loose u may consider gettng a different one or doing a little chisel work on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 1:27pm
Talking with a neighbor this morning about the problem, would medium strength loctite be what a person should use when installing the cap into the trans housing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 11:48pm
Took the pto housing off the back today cap was laying inside also the bolt that threads into the end of the axle, must have turned out and pushed the cap off. Good thing the axle didn't seem to be moving around. When cleaning the rear housing for reassembly found some small metal pieces, lower front bearing in the pto housing was close to failing, balls still in the bearing but the metal that keeps them in place was what I found in the bottom. So need to find a new bearing tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 7:00am
So maybe it was a good thing it started leaking before any Real damage was done internallySmile
