170 or 180 pic and i need to decide Dang Ac
CTD03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Topic: 170 or 180 pic and i need to decide Dang Ac
    Posted: 11 May 2012 at 11:15pm
the 180 1st pic
the 170 2nd 2 pics
well I ever only plan on during maybe 2 acres or pumpkins a year and some small time square bales and running the new idea cutditioner probably 10 acres of junk hay till i can afford better. but mainly just hobby pumpkin patch. O running a manure spreader and maybe a lime spreader also.
I plan on getting a tiller thinking 6-8 tiller I would need to change over one of my plows to 3pt dont know if that can be done and make my ac disk draw bar or get my d17 engine running better but I want to buy a tractor and dont know really what I should do.
So i am putting up pics for all you to help me out. I really wanted a diesel but both tractors have caught my eye
Indiana farmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Indiana farmboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 11:39pm
both very nice tractors but i would have to pick the 180 because it is a landhandler version little more rarer to find
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 11:45pm
what is the landhandler? I couldnt find any info on them.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 12:22am
I'd take the 170, easier on fuel and the power director is mechanical instead of hydraulic which gives you much better control when using the hand clutch. It also sits lower and is a bit shorter making it  a more nimble machine.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (1) Thanks(1)   Quote Indiana farmboy Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 12:27am
that is a good point i guess it depends if you look at it from a useably stand point or a collector stand point
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 12:28am
170 would be my choice for exactly the same reasons, plus the sound of those AC 4 cylinders is one of my favorite tunes.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 4:02am
Landhandler means nothing - just a decal, if they are gas burners, go with the ONE SEVENTY, much easier on gas
Longmeadow Farm View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 5:30am
If you are going to look at it, pick the 180, but if you are going to use it buy the 170... mechanical power director has a much higher utility value and the 170 will use a lot less fuel. The  170/175s are a well balanced unit and work well as a chore tractor and for stuff you want to do.
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 6:21am
hay ctd03 is that one eighty at harts eguipment?
6060 s\n 5016
1947 JD B
Post Options Post Options   Thanks (1) Thanks(1)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 6:47am
For what you are going to do with it I would take the 170. Like others have said better PD and use alot less fuel.   MACK
Matt MN View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 3:15pm
If you are Collecting then buy the 180 Gas, if you want a great all around tractor then go with the 170, The 170 is much more handier for small jobs.
ky wonder View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 3:16pm
all things considered and mecanically the same condition , i to would opt for the 170,
decent little mid size tractor dual hydraulics hook ups, easy to drive nimble tractor, 3 point tools are much easier to find than the ac coupler implements
the 180 is a big horse in a two acre patch
i like old tractors of all colors
Orange Blood View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 4:53pm
Well since everyone has you talked into the 170, where is the 180, and how much will it take to buy it?
Still in use:
Josh Day View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 4:59pm
Buy both
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 11:08pm
sorry I didnt post during the day. I was busy mowing yards and went to help my gf out with horses.
I like them both.  I do agree the 180 is alot of hp for what I want to do. The 170 would be perfect.
Kinda like the idea of collecting. I told my self today it would be just a toy the 180 cant be that hard on gas...
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 11:14pm
       i had an AC DEALER tell me that the LANDHANDLER had higher gears then a non-landhandler i dont know???
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2012 at 11:17pm
You can do a little job with a big tractor but you cant do a big job with a little tractor--- i would get the 180.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 4:21am
Personally if I had the cover for them...both.
realolman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote realolman Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 6:16am
180 looks nicer to me.  tires are shot  on the 170
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 9:56am
Yes, but with 10 or so horsepower difference the 180 won't do much bigger jobs. LOL
They are both good looking tractors but what is the price difference? That would be a factor for me too, although I'd lean towards the 170 unless the 180 was cheaper. If the 180 was a diesel I'd go that way but I've owned a 190XT gas and I can tell you that thing was REALLY hard on fuel. My D17 series IV could mow more than twice as much ground with the same mower and the same amount of fuel than the XT would.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 10:57am
Tires are shot?  There is alot of use left in those tires.  I would take them over those Censored long bar/short bar on the 180.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 12:16pm
going to call about the 180 monday and the 170.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 12:34pm
I think both tractors are very nice. The tires on the 170 will still last a long time and have a lot of life left in them. Also notice the original top link on the 170. In my opinion and from experience,the 180 is a lot bigger work horse than the 170 with the extra horsepower and weight working in it's favor. As for the tires on the 180,and I know this has been discussed several times over,I'll take them over the ones on the 170 any day. They pull better in my opinion,but they are rough riders when on the blacktop. However,i don't road mine,I haul them where they need to go,unless it's across the road or only a mile or two. Lastly,yes the 180 will be harder on gas than the 170...we're talking 6 cylinder verses 4 cylinder though. I guess it would depend on what job you were going to use it for. It would be really hard to pass one or the other up though,so I would have to go with "get 'em both"! LOL!  Rick
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 5:30pm
For what you are using it for,it would be a no-brainer for me. The 170 would be my choice. It will be much cheaper to operate and the power director is very easy to use. The only advantage the 180 would for you is that it does have fully indepenent hydraulic PTO. On the down side,the 180 will be a true gas guzzler and the power director on 180 and 185 models were the worst design of any AC tractor. Very difficult to creep or feather it while looking back at implement. The short shift lever and location of it just plain sucks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 6:10pm
Thanks for all the input. So much info from you guys I can't get enough of this. I still am tore between the tractors witch to get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote realolman Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 6:27pm
I'm sure there'd be a lot of people willing to trade you..   I'd be one of them.Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 6:50pm
Buy both if one breaks down you have one to keep you going until other is fixed. (my thought)
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 8:28pm
I agree that the 170 would be better on a smaller operation. I'm not sure about the Landhandler designation, I thought it was the Crop Hustler that had the higher speed gearing such as the 185.
HD16,917H,185,7050,8030FWA,8050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 10:38pm
Landhandlers were the tillage tractors 180 & up, Crop Hustlers were the smaller tractors.
