Model B Hydraulic Pump
Daniel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Quote  Post ReplyReply Direct Link To This Post Topic: Model B Hydraulic Pump
    Posted: 09 May 2012 at 11:28pm
Just got the B back up and running again, changed the trans fluid after I got it running with 303, I'm having trouble with the hydraulic pump holding the plow up, it wants to release the hydraulic cylinder, it wants to hold it up part of the time and when it doesn't pushing the lever down and releasing pressure for about 3-4 seconds then raising it back up will cause it to hold. Any ideas on how to fix this?
This is the original pump on my '39 B.
Daniel
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 5:49pm
Daniel I can`t help but your post needs a bump.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 7:48pm
Had a similar problem on my 49 B. Take pump off and flush with a good solvent, if that don,t work remove bypass valve and have seat  recut  and reinstall with barrel down 9/16 in in hole . My seat was boggered  up and machinest took  .010 thousand off it and now it works great , will hold plows up for days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 8:06pm
Any one of the check valves could be leaking. If you take it apart and find any pits in the small balls for the check valves, you can buy replacement bearing balls the same size. You get twice as many as you need and use the first one in each position to smack with a punch and hammer to reform the seat. Then throw that ball away and put a new one in and replace the spring. It doesn't take much to reform the ball seat, but if it has been leaking it should be done.
 The pump is pretty simple, just get a drawing of it from a manual, and make sure you have a clean work surface with room to lay an old towel down under so you can catch any parts that want to roll or bounce away.
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2012 at 9:35pm
Good information. Tag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 10:30pm
Thank you SO much guys, I will do as suggested! Sunday I plan to work on it!
This page was generated in 0.087 seconds.
