G crankshaft pulley from Steiner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: G crankshaft pulley from Steiner?
    Posted: 07 May 2012 at 10:25pm
Has anyone purchased a crankshaft pulley from Steiner's? I bought 2 and the bores are too tight by .002 , and keyways are not broached to correct depth. I called them and they will take them back, but have had no complaints. Just wondering if I got the only 2 that were incorrect. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 10:40pm
I doubt it.Don't you love Chinese workmanship?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 10:48pm
I can fix them, just didn't want to. Can't buy much that has quality any more. Tracy Martin
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 8:43am
Tracy. Did you try them on a G crankshaft or just compare measurements to a original pulley?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 9:48am
Tried them on the crankshaft, then measured them. Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 1:33pm
One thing about it Tracy.If you "finish" it it be have the correct spec/fit. Kinda a bugger workin around that interupted cut though.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 2:55pm
Tracy: Seems like one should not have to machine a new part, unfortunately with the outmigration of corporate America oversee's we are left we having to be self reliant.  I know that you are a wonderfully skilled craftsman and have no doubt that you can machine a broach and clean up the center hole to .002.
I have run into similar problems in the past and that is why I put in a metal lathe last year and will be adding a Bridgeport or similar very soon.
Hard to find precision in today's society.  Good luck....Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 3:24pm
I got them finished. I wish I had the choice of low,middle and top quality when buying parts. There ain't no free rides. No way a man could of ever got that pulley over the key. But, they said they have had no complaints. Tracy Martin
