D15 gen
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: D15 gen
    Posted: 05 May 2012 at 6:13pm
question for all you electron experts. I have had a rebuilt original D15II gen and new matched VR on my 15 Diamond in the rough. It has never shown a charge or discharge. I r&r VR cleaning/shining up how it's bolted to the battery box frame. I have removed the gen. I'd like to test the gen but the local shop isn't open till Mon and I don't want to wait. lol Any easy way for me to check and see if she's puttin' out correctly or should I work on something else 'till Mon?
Edited by captaindana - 05 May 2012 at 6:13pm
DEP5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DEP5 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 6:16pm
Using GOOGLE, search -> how to test a generator
D10 Series III, fully optioned
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 6:26pm
Hook the generator to a battery (A and frame). With the field open it should run about 1500 RPM. Connect the field and it should run slower but have more torque.
Check as a generator with a motor. With the field connected it should generate voltage. How much depends on the details of the design and the shaft speed.
Ammeters can fail with the pointer pivots rusted fast.
Check the ammeter by turning on the lights without the generator or without the engine running. If the lights light and there's no discharge indication, the ammeter is bad or not connected.
Ammeters are cheaper than generators. And a better indicator of circuit function than a voltmeter.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 7:00pm
Thanks Gerald. My ammeter isn't frozen...I can see it dance slightly, I removed all my lights so I can't check with them; hmmm let me think what I can hook up to where...to get a draw. Think I best not think till I get some rest loL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 8:44pm
So if you had the generator rebuilt and put a new VR on, did you flash(polarize) the generator before running it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2012 at 10:16pm
One of those headlights you removed is a decent test. Or a spare headlight lamp. Wire it to the terminal of the ammeter away from the battery wire.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 5:59am
Thanks guys I am off to fix this...Charlie when I flashed it I thought I was arc welding without a helmut! It scared me; no little spark it was huge!
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 8:57am
Many thanks as usual for the help! Thank you Gerald and Carl and Charlie. I fired her up after cleaning and reassembling everything and tracing wires. She went right up at charge to 10, then came back eventually to just positive. Lovin' it! Thanks again amigos!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 9:03am
Cap'n, me thinks your traction booster gauge might not be workingLOL
