D 15 II Front sel and Oil line packing Ques?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: D 15 II Front sel and Oil line packing Ques?
    Posted: 29 Apr 2012 at 6:37pm
Other projects have gotten ahead of this ole D 15 II series two since it was torn down a few years  back.  I think I am serious about getting it off the barn floor this time.
On the front crank seal.  Surely it goes in with the felt to the front or outboard?  Also since I don't have the seal expander referenced in the manual, what do you folks use as a technique to get the seal installed/on without turning the lip over.  I can see it is gonna be a challenge after a speedie sleeve is installed.
On the oil tubes like the filter base to the block, has anyone come up with a replacement?  It appears (even if it is still aavailasble) to get the sleeve one has to buy a nut with each sleeve.  thanx
Edited by Dave H - 29 Apr 2012 at 6:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:00am
common guys, I am treading water here. Confused
