Allis B transmission noise
Emmo213 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Emmo213 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B transmission noise
    Posted: 27 Apr 2012 at 10:19pm
So this is my first tractor and it wasn't until last year that we had it running. I did have a professional do some work on it because I ended up getting over my head for awhile. My question is: when I engage the clutch it makes a weird sound. I don't know if this is normal or if something's wrong. It doesn't seem to affect the driving of the tractor as we've had no problems with it. I'm just curious what people think. Ive attached a video that clearly displays the noise when I lift off the pedal.
[TUBE]OtmcwlaXxlo[/TUBE]
'38 Allis B
'41 JD A
Post Options Post Options   Thanks (0) Thanks(0)   Quote Emmo213 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 10:41pm
And here's a short video of it running.
[TUBE]aWUZG2cLyf4[/TUBE]
'38 Allis B
'41 JD A
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 7:30am
I'm not an expert on B's but I think you have somthing wrong with the trans. good luck with it, keep us updated.
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 9:31am
Mine makes that noise when the Hydraulic/Trans fluid is low. It will make the noise in or out of gear. I fill it up and the noise goes away. I definitely have a leak, but it's cheaper for fluid than to tear down the rear end and look right now!
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 12:44pm
I'm not sure, because I haven't had that noise with any of my tractors, but here are some things you can try to narrow down what it could be:
In the first video you engage the clutch but do not move forward.  So I'm assuming you do not have the tractor in gear.  If that is the case, and IF the tractor has hydraulics/pto/belt pulley on the rear, and IF that is ENGAGED, than that is telling me that the noise could be in that part of the tractor and NOT the transmission.  IF you DISENGAGE the pto/belt pulley/ hydraulics (a lever on the right hand side attached to underside of bench seat) does the tractor still make this noise?  If not, then your problem is contained to the pto unit and not the tranny.  If so, than I'm sorry to say, that to me it sounds like a tranny problem.  Possibly a bad bearing?  I don't really know, I haven't had to deal with that, like I said.
Let us know what you find out with what I suggested, that will narrow it down.  Good luck!
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
