TRACTION BOOSTER
Bigrigger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bigrigger Quote  Post ReplyReply Direct Link To This Post Topic: TRACTION BOOSTER
    Posted: 26 Apr 2012 at 6:27pm
Has anyone had the line coming out of the back of the traction booster gauge burst? I was on the last pass in the garden with the D-17 and a 2 bottom sc plow in 3 low when I noticed hydraulic fluid streaming down the side of the torque tube. Pulled the side panel off to find that the line had burst just behind the brass fitting that attaches it to the gauge. No big deal since the gauge rusted out years ago. Figured I could just plug it at the port on the top of the torque tube. However, the specialty fastener store couldn't even match the fitting on the other end of the line. I have seen replacement gauges that are supposedly "working" gauges. Has anyone ever bought one? Do they really work? More importantly, do they come with a replacement line and fittings? Also, could there be a bigger problem that caused excessive pressure and that just happened to be the weak point? Meaning... if I replace it, could something else blow? I'd appreciate the help cause I'm dead in the water until I can at least stop the leak. Thanks.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 9:04pm
Just put a new TB gauge on my D-17 ser.3 a couple months ago. Got it from DJS tractor parts and works perfect. Also had to replace the supply line,but had to get it from AGCO and it cost around $80.00 The supply line had a tiny pinhole caused by the throttle linkage rubbing on it. I feel AGCO root wadded me on the line,but it did come pre formed and fit perfect. I think the new gauge was around $100.00
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 9:15pm
This line also leaks on our series IV diesel. Hope to replace or fix it some time.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 9:28pm
Go to Advanced Auto or O'reilly's and get a "HELP" oil line for about $11.00. It had all of the fitting in it that I needed to replace my leaking Traction Booster oil line on my D15, including the adapter to go from 1/8" pipe to the tubing. On my CA the tubing is connected using a double flare fitting and a flare nut. Bob
Edited by Chalmersbob - 26 Apr 2012 at 9:30pm
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 12:00am
Shouldnt even need traction booster pulling a 2 bottom with a d17
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 1:44am
I started to do like "Chalmersbob" did and go auto parts store,but I figured all they would have is a line for engine oil pressure gauge which is fairly low pressure. I don't know how much pressure this line has on it,but I know it is way,way more than engine oil pressure. Maybe a piece of brake line tubing would work,but I figured what the heck,it's only money and got it from AGCO. I guess more than anything,I just wanted to keep my tractor original as possible.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 6:03am
when ever you raise your rear lift watch the TB gauge, it gets pressurized when ever the pump kicks in.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 7:11am
No, but it is HI pressure so it dont surprise me
I do believe the fitting is an inverted flare 1/8
1968 D15D,1962 D19D
alan1959 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 6:35pm
Would you happen to have the part number for the line? I too would like to keep it original. But if it is too much.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 6:43pm
YABUT there is no NEED for the gauge. You can buy an oil filled 5,000 PSI gauge for about 15 Bucks from most any supplier of such things and it will work just as good or better than a $100 repro Allis Gauge. Not for the purist but..........Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 6:52pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 7:13am
Don't buy a new repro gauge. I bought one and after a few months the needle fell off. Next year, the face filled with fluid and popped the glass. Several others on here had similar problems. Either get it rebuild, or take ctucker's advice. I gave up and have a nice 5000PSI gauge on my WD45 for $20
