385 Planter Advice Needed
AllisUpstate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Topic: 385 Planter Advice Needed
    Posted: 26 Apr 2012 at 8:24am
I really appreciate all the technical help everyone has generously given on the forum.  With that in mind, I probably will be testing everyone's patience as I finally try to get the 385 4 row planter ready to use.  I picked it up late last fall from an auction, and this is the first time I spent any time getting it cleaned up.  It appears to be in good shape, and was used prior to being put away.  Everything is intact and in good condition.  So it is not a junker I have to restore.
I will be using our D17IV on it.  I had asked this question before, but I kept the D17IV with the generator and + ground.  I'm not worried about it operating the fans, but the seed monitor I'm pretty sure will need a negative ground, as it contains solid state electronics.  I'd like to keep the generator, as it was new last summer and I finally have the charging system working great, after 3 bad aftermarket regulators.  I found a NOS regulator, put it on and everything charges like it should.  So the first question is, can I switch the generator/regulator over to neg ground without a problem, using the stock Delco regulator?  The alternative is that I can live without the seed monitor, and avoid the hassle.  I'll only be doing 10-15 acres at a time, and it seems as long as I check things frequently for blockage, the seed monitor may be overkill.
I've also never used an air planter before - we always used seed plates.  Anything in particular I need to look out for when using this planter?  As I start to do some test runs, I'm sure I'll have more questions.
We had snow last week, and deep frost at 21 deg this morning, so at this rate I'll have until about June before we get to plant, so plenty of time to grease the planter up!  Should have planted back in March when it was 70 degSmile Gotta love upstate NY - never a dull moment weatherwise at least.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 8:28am
If you are only doing a few acres at a time, why not just use a separate battery for the monitor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 8:52am
Ted,
Thanks.  Good idea to just run the monitor itself separately off a battery.  Is it even worth bothering with monitor?  Do these planters tend to plug up often?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:18am
You shouldn't have a problem plugging up but if you like to make turns such as planting round a corner (don't do it) you can run the chains off the units, or if a corn stalk gets kicked up and runs one off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 10:01pm
If you run chains off going around corners you have a worn out machine because they drive from front.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 10:32pm
The chains that drove the individual units were the ones we had problems coming off, What added to the probem was we had rawson notill coulters mounted up front and when you turned it would always pry the back of the planter around with those coulters up front.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 10:27am
We ran a 78 series with blowers for years - just have to reverse the polarity.  On a 385 there were two versions of monitors, one had single box with the blower switch inside and the later ones had an extra soleniod box. Do not use the internal proir box to power the blowers on a pos ground , just hook pos to pos and neg to neg batt post and mon will work fine - it is isolated. (Late models boxes can be used but do not connect to the seed monitor - use a separate switch).  Hook the blower wires up to the battery and put a heavy duty switch in line and plant.  Make SURE the rotation of the fans is correct. It is just like a baseball pitching machine it turns to 'throw' the air out of the snail shaped housing.  Good motors only pull 6 amps approx. So unless you have halogen super lights, you gen will be fine.  NAPA sells a motor SP1291 or PM357 that will sub. for much less $ than oem 70583068 blower motor if needed.   After seeds are in the discs and rotated one  turn - with blowers on - listen for the 'whistle' coming from each box.  That tells you you have correct air pressure -2 - 2.5 water column inches of pressure.  Make SURE seed discs seal.  Early models have plastic plate  to plastic hopper seal, late updates had a metal wear ring glued onto housing -grrr a bear to keep up. Check the seed pads for wear or cracks. Landol offers a great aluminum hoppper replacement - worth every penny.  When the hopper is set down on/ in the frame the clutch driver shaft should fit perfectly into the seed disc retainer, if not adjust the hopper for fit - it is the hopper nut that serves as the locator and stabilizer for the shaft - if the hopper moves or is not lined up - bad things happen.  As to chain run off , there was an update to add a heavy plate -71509786 to prevent frame flex.  We always added extra idlers, added extra chain and wraped the drive and driven sprockets as much as possible.  There are two sprockets on the driven clutch sprocket.  On many planters we ran a chain rearward to a dummy pre loaded idler to pull back and relieve forward stress on the bearing. Make sure unit parallel linkage bushings are good and tight to prevent frame walk as the leading coulter will pull the unit sideways in hard ground.  There is a floating scraper between the discs and in front of the seed tube - there was a update to weld a short 3/8" keystock to this to protect the boot and scrape the insides better .  It needs to just touch the bottom of the seed trench or be just shorter than the opener s at the bottom - it is called  a floating scraper.  Grab one disc - with gloves on- and pull while holding the other opener touching it still.  Should take a few pounds pull to acconplish - if you cant pull one with the other stationary - they are too close - add shims between the brg and frame on the brg bolt - if they do not touch remove shims.  This is important.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 3:52pm
tbran and others,
Thanks so much for the help!  I am going to try to get everything hooked up this weekend.  If I can use the D17 + ground, that will save me a lot of hassles.  Once I start crawling around it more, all of these posts will make more sense, and I will be sure to check all the critical details.  I sure wish this thing had regular seed plates, but hopefully it won't be too fussy.  I'll keep you all posted how it goes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 9:55pm
A medium seed disk will plant ungraded medium seed no problem if you have small seed use small disk and large for large,very forgiving, you will notice a slight change in population if you get to far out of range, but much better than trying yo deal with the old plate planter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 6:30pm
Just a quick update on my progress getting this planter up and running.  After going back and forth in my mind a few times, I just decided to try to reverse the generator polarity, rather than switch to an alternator, or try to play with the planter blower motors or monitor electronics with a positive ground.  Switched the battery and coil terminals, as well as the ammeter connections and flashed the Battery and Armature leads briefly.  Sterted the D17 up, and no charge!  I was about to start the alternator install, but decided to try to flash it a few more times.  This time, it started charging correctly right away.  So for all you flashers out there, it seems to take several times before the generator takes notice.
I got the planter powerbox located and wired up to the battery, and I was one happy camper when I got both blower motors working properly.  One was kind of stuck, but freed up after a bit of prodding, and after a few minutes was blowing at full speed just like the other one.
Now I'm down to just mechanical issues, in terms of freeing all the chains and bearings up, and just generally going over everything.  It looks like the planter was used and cared for, but then stored outside uncovered for a number  of years.  Nothing is missing,  but some things are a bit rusty and seized - nothing some drain oil won't fix.
The weather is finally warming here in upstate NY, but it is still going to be about 2 weeks befor corn planting.  Despite warm days, we are still dropping into the 30's at night all week.  The apple crop in NY this year is pretty much devastated,  but everything else should be ok, but about a week or two late for planting.
Onwards and Upwards!  Now for the fertilizer bins!
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 9:10pm
What city are you near?  Upstate covers a lot of territory!  I was in Watertown, Syracuse and Cobelskill last week.  Have been using a 385 for 22 years and it still beats most of the new planters for seed placement and reliability.
Edited by Russ-neia - 06 May 2012 at 9:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 6:58am
Russ-neia,
"Upstate" is pretty big.  Of course, everyone down by the "city" refers to everything north of White Plains as "Upstate".  We're about 80 miles southeast of Syracuse and 50 miles northeast of Binghamton, not too far from Oneonta.
I'm really looking forward to getting this planter all fixed up.  This will be my first no-till experience.  I figure I will make plenty of mistakes along the way, but want to start to learn how to make no-till work, and play with different cover crops and such.  The 4 row is suited to our smaller acreage (only 60 tillable) and small fields (5-10 acres).  I found a Gleaner F2 with a 4 row narrow head (plus a 12 foot grain header), so with that combination, I should have a nice little system to experiment  with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 9:08am
Shoot!  I should have looked you up!  Wasn't very far from you as we made stops in Cobleskill, Middleburgh, and Fort Plain.  I was impressed to see so much orange in the area.  Must have had some good dealers in the past.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 10:21am
Russ-neia....What are you using for the adhesive for the seed rings?  Dealer told me 3M #847.  (3M™ Scotch-Weld™ Nitrile High Performance Rubber And Gasket Adhesive 847).
Also do you have the later version seed rings with the tabs on them?  Thanks...Dale
Orangereborn
Dale Schafer
964 192nd Ave
New Richmond, WI 54017
715-247-3079
715-781-2055
Orangereborn@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 2:13pm
The 3M product sounds right.  I bit the bullet and upgraded to the aluminum "Landoll" housings without the wear rings.  They were always giving me fits and getting rusty.  The wear rings might be O.K. if they had been made out of stainless instead of galvanized.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 2:52pm
Just my opinion, all the time you have spent on here asking questions you could have converted to alternator and been done with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 1:47pm
The 385 planter is almost ready to go.  Now I am down to a trivial problem of finding 2 new air hoses to connect from the blower to the shoe, as two of the old ones are reallly shot.  The hoses are 2 1/2" ID.  The smallest flexible dryer hose I can find is 3".  Just for fun, I checked on the Agco part, and there are some in stock around the country, for $189 per hose!!  I figured I would take a pass on them.  So far, I have not had any luck finding any similar hoses at local equipment dealers.  I can get a dealer to order some from Landoll that has them in stock at $4.50 per foot, but they say it will take probably 10 days or so.
If I have to, I will try to crimp some dryer hose shut around the pipe and seal it, but I was just wondering if anyone has some clever source for this size hose?  I even tried swimming pool dealers, but their hoses are either too small or too big. Plumbing supply houses also don't seem to have anything flexible at 2 1/2".
Thanks.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 4:08pm
McMaster-Carr would have the hose. You could use heater ducting from NAPA or some other auto parts store for temporary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 7:38pm
Shop vac hose should also work, and it's available in 2 1/2 inch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 10:01pm
Go to McMaster-Carr and look for dust collector hose.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 10:37pm
For the dust collector hose you could check your local home depot, lowes, menards or fleet farm or whatever you have close by.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 11:50pm
i bought an air champ planter (unk what #) for parts for my planter...(mainly the seed boxes) . i see the previous owner put fertilizer hoses on the fans. musta worked, it was his ony planter! i don't have the air planter, think mine is the 600 series. but alot of the same parts on them that interchange! my old plastic boxes are about shot...and they are expensive! and the new ones are even brittle!. i found out that by grinding off the rivets, and removing the fiberglass boxes from the base, they will bolt right on the older seed bottoms! same holes. and they hold more seed!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 11:59pm
you might also try old fire hose...your local fire dept may have some laying around!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 6:34am
Thanks guys,
You're right.  Thanks for the tips.  I did some internet searching, and found 2 1/2" woodworking venting hose in 10' lengths for $14.  I still wasn't able to find any in stock locally, although the idea of NAPA for heat vent hose was a good one.  Anyway, it should be in within a few days.  Corn planting is really just starting to get underway locally here.  Weather for the next few days still calls for ~ 30 at night, and soil temps are still low, so I should be able to get the new planter going in time.
