d-19 carb ???'s |
Post Reply ![]() |
cornbinder ![]() Orange Level ![]() ![]() Joined: 26 Sep 2011 Location: jeromesville,oh Points: 846 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Apr 2012 at 4:00pm |
looking to buy a carb kit for our d-19, i see 2 different carbs listed. zenith, and shebler. anything i should be looking for to tell which one we have? any input would be appreciated. is any brand name kit better or worse than the other? thanks, pete
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11992 |
To ID your carburetor, you need to look at the tag. Large bore Marvels, usually have their square tag riveted to the throat of the carb. Large bore Zenith's usually have their tag riveted to the fuel bowl. Either will have the name on the side of the Carburetor to ID the mfr. The M/S carbs ID tag starts off with TSX-XXX followed by three digits. All of the carbs that I've rebuilt for our customer's off a D19, were large bore Marvels. Usually, a TSX-848. BTW, we do carry rebuilding kits that will do the job for you. Our kits do not have new throttle shafts in them, but in most cases, if it needs throttle shaft work, the throttle shaft bore needs to be bushed or sleeved anyway.... HTH
Steve@B&B |
thanks for the info. when i see which carb i have i will look you up and get one sent out here to n.east ohio.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21836 |
All D19's had the Marvel TSX848....the Zenith carbs were used on G262 combine engine applications.
Post Reply ![]() |
