Roto Baler question |
jessejmc1979
Topic: Roto Baler questionPosted: 16 Apr 2012 at 9:34am |
I have been looking for a baler for our small hobby farm. We have 6 acres of hay ground and have been splitting bales with a neighbor for his fuel and time baling small squares. He is 75 now and stated last year that this year would be the last year he wanted to do it and I should start looking for my own equipment. I bought a wd45 last fall that is in really good shape and my goal this year is to find a baler and a rake, and next year get a haybine. I have recently seen a few roto balers and just can't shake the thought that they would work perfect for our setup. I know that they are old but from what I've seen they are pretty simple and aside from the stop and go would be kind of neat. But for every roto baler that you see there is 50 small square balers. So I guess would it be stupid for us to get a roto baler and go that route or is it much less of a headache to just bale squares? Thanks for any info.
allischalmerguy
Joined: 11 Sep 2009 Location: Deep River, IA Points: 2894 |
Posted: 16 Apr 2012 at 9:25pm |
I think it depends on what you want to do with the bales?
If you are going to sell them...I think you will have a hard time selling roto baler round bales. BUT if you are going to feed them yourself, and stack them in a barn, why not get the roto baler? I suppose it might depend on how much money you want to spend too. And what you can find in a used square baler and used roto baler? Since you have the WD45, you are set to run the rotobaler too. Just my thoughts. Pastor Mike |
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 999 |
Posted: 16 Apr 2012 at 9:30pm |
I run a few hundred bales a year with mine. Its the only baler I use in my small beef operation. I like it. I like feeding the bales and I really like bedding straw that has been Roto baled. I say go for it and be different.
Life is simpler when you plow around the stump.
jessejmc1979
Posted: 16 Apr 2012 at 9:43pm |
I'm sure that we would be feeding out most if not all of the hay that we bale. So selling it isn't a huge concern. We got just about 1,000 bales last year out of our field and I'm sure it will be a touch less (unless it stays as dry as this spring has been). So do you guys think that a roto baler could handle 1,000 bales per summer. I have read that they are super simple to keep baling. I was thinking the same thing that since the roto baler was designed for the wd then why not. The only problem now is finding one. There is one in a field that has fairly new belts (they are still very black) from what I can see from the road, and I'm gonna stop at the farmers house tomorrow and see if I can take it off of his hands. Thanks for all the info guys. I appreciate it.
MACK
There are alot of them in my area. I have one I would sell and know where there is a late one that has been in shed until the last few years. MACK
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4974 |
Posted: 16 Apr 2012 at 10:08pm |
Our family had one on our farm before I was born.I grew up with square bales until 14 when my father found a used white top roto baler to replace the case square baler that kept breaking and needing parts replaced. He preferred the roto baler because it only needed fine tuning from time to time to keep it going.We fed out all of our hay and I could see it be an issue selling bales. I did not see much difference in handling bales.2 hay hooks are necessary. They pack just as tight but can be harder to walk on. Raking hay properly is essential in making even nice looking bales.Have to rake 2 rows side by side as wide as the bales. Binder twine instead of Baling twine. Most farm and home stores can still get it. You already have the WD45 so I would say get a roto baler and be sure to post some pics.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
jessejmc1979
Posted: 16 Apr 2012 at 10:16pm |
Hey Mack: where are you at with all these roto balers around? I've only seen 4 of 5 of them around here and all but 2 have been completely shot. I am hoping to find one because I think that might be the only way to go.
Jim Lindemood
Joined: 22 Sep 2009 Location: Dry Ridge, KY Points: 2569 |
Posted: 17 Apr 2012 at 7:01am |
Jesse - if you do think that you might end up selling some bales in the future, better stick with a square baler. I like the romance of a WD45 and a rotobaler, but only if you are going to use all the hay on your place. (wish I had a rotobaler to play with) -- we sell all our hay, square bales for horse customers and large round bales for cattle customers. Would be difficult to sell the small round bales from a rotobaler.
jessejmc1979
Posted: 17 Apr 2012 at 9:31am |
Well I just got done checking out that roto baler that I saw setting in a field. I appears to be in good shape with the exception of the belts. The bottom belts are pretty much shot, and the top ones don't look too bad but if it's not a huge job I'd rather just change all of them and be done with it. I didn't have a camera with me otherwise I'd have taken a few pictures to show you guys. All of the sprockets look good and the only thing that looked rough was there is a rubber looking bushing type thing on the outside of the pickup ramp on the left side that looks pretty bad. With my horrible description does anybody know what that would be and can a guy find the part to replace it? Also is the belt changing something that I could do myself or would I have to take it to the dealer? He said he needed to get $275 out of it because he bought it at an auction 2 years ago and that's what he has in it. Does that seem like a good price? Also would it be dumb to grease it up and have him hook up to it and make sure everything goes? Thanks for the help fellas!
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 17 Apr 2012 at 9:45am |
I don't know what belts cost for these things, but $275 is about as low as you will find for anything of that size since scrap iron price is so high. I would absolutely ask to see it run, but if he doesn't want to, don't take it the wrong way, it's basically scrap price. So if it looks good, it is probably good on the inside, there isn't much to go wrong, and if it did, you can typically find another one for about the same money for parts.
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
jessejmc1979
Posted: 18 Apr 2012 at 2:54pm |
So now I have another question. That roto baler that is $275 and needs new belts has my attention but belts are around $500 and labor to change the belts is $700. I would have $1500 into the baler assuming nothing else is wrong with it. I would like to get the roto baler but from what I've seen I could get a really nice small square baler for $1500, but I'm sure I'd have to stick some money into that also. But enough rambling my question is how long can a guy expect new belts on a baler to last? And also is it possible for a guy with a little mechanical know how and determination to change the belts by himself? I also would have to come up with a splicing tool so I know that would be another cost. Thanks for any info fellas!
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 18 Apr 2012 at 5:45pm |
I have never worked on a roto baler but if you have spliced belts, changing the belts can't be a bad job. To replace the endless belts seems like you have to get to know the baler REAL well by removing half of it.
MACK
Posted: 18 Apr 2012 at 10:08pm |
I wish you lived closer to me, I would change the belts for alot less than 700. Back in the 60s and 70s another guy and I could change a set of belts in 1 hr. Back then I would go out after work and change a set for $20. MACK
jessejmc1979
Posted: 19 Apr 2012 at 8:02am |
Thanks Mack! Nothing like rubbing it in! LOL I found an implement dealer by my house that charges $45/hr but only has a 125 alligator splicing tool and wasn't sure if he could splice the belts that I would get specifically for the roto baler. But he has rolls of baler belts but they are 12" wide. Could a guy rip those belts to 5.5" and use them instead of buying the belts specifically for the baler? That would be quite a bit cheaper then if it would work. I appologize for all of the rookie questions but I really don't know anything about round balers but I would like to "get in the game." Thanks again for any insite.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 19 Apr 2012 at 2:20pm |
I worked with our mechanic to replace one belt. Took about an hour. Wish I could remember what he did. Belts were endless.
Did not seem that hard. Worked from left side facing to rear Maunal would help. Good Luck! Bill Long Edited by Bill Long - 19 Apr 2012 at 2:22pm |
TomYaz
Posted: 19 Apr 2012 at 7:33pm |
Good to remember that line the next time my wife complains of no romance in her life..
jessejmc1979
Posted: 30 Apr 2012 at 11:59am |
Well I'm still milling around the idea of this roto baler. I stopped and looked at it again last week and noticed a spring that was connected to the twine feed deal (I know technical term) that was broken. I saw online that I could get a spring kit and new twine knife for like $57. That's not soo bad and I would be able to do the belts by myself so I'm just wondering if there's anything else that I should be looking for before I pull the trigger. The sprockets look good and the chains look alright also. Were these things bulletproof or is there something else that I should look at that would be a deal breaker if it's broken. Thanks!
Bill Long
Posted: 30 Apr 2012 at 4:25pm |
Jesse, Just remember you are looking at a machine that we sold in 1948 which means any wheres up to over 60 years old. That to me means that the gearing and bearings could be trouble. I know they sit in oil but oil that does not circulate can cause the bearings to rust and have to be replaced. You may want to be sure everything turns. Take a bar and put in in the pto yoke and see if it turns.
The roto baler is rather simple but needs very good careful adjustment. A manual will be most helpful. There are latches that hold the rear together. May want to check those along with the springs. In any event let me wish you the best on your contemplations. Good Luck! Bill Long |
DaleinWI
Joined: 27 Oct 2009 Location: La Farge, WI Points: 48 |
Posted: 09 Jul 2018 at 10:49am |
Can someone advise me on the installation of the upper belts on the Allis Roto-baler? How do you get enough slack to hook the splices together? I have unhooked the discharge springs and opened the latches so the lower belts are loose as it would be to discharge a bale but the upper belts are still relatively tight. I have tried a ratcheted load strap between the upper and bottom rollers (of the upper group) but that didn't seem to help much. Do i need to raise the bottom roller of the bottom belts, the one with the gear in the gear rack? I may try that next. Any advise/help would sure be appreciated. Dale
Krazy Karl
Posted: 09 Jul 2018 at 9:30pm |
There a big tension spring on the right rear side can loosen up to take belt tension loose. When i did mine the bottom ones seemed easy to connect. Also make sure the brake is not stuck on the lower roll make sure that is free before running baler also
MACK
Posted: 09 Jul 2018 at 9:41pm |
I would not advise using spliced belts. They are good to get by with until endless can be put on.
To loosen top belts, trip it open like you have, loosen brake on right side, use a handyman jack under lower roller and jack it up. MACK |
Dakota Dave
Posted: 11 Jul 2018 at 5:41pm |
Back in the 70 s we changed allthe belts on the roto baler we baled 6000 bales a year and the belts were 20 years old at the time. It was an all day job to replace all the endless belts. Spliced belts could be done in A hour easy open the baler loosten the tension spring cut the old belt out tie the new belt to the old one with bailing wire and pull it through
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2043 |
Posted: 12 Jul 2018 at 7:52am |
Where do you get endless belts?
