WD 45 Single Wheel & Gearboxs
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Single Wheel & Gearboxs
    Posted: 10 Apr 2012 at 7:57pm
2 complete gearboxes and single wheel.  I will sell whatever you need.  Call with questions 785-353-2392.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 9:04pm
Tire size that was used on the single wheel.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 9:09pm
Should be 9.00X10.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 9:51pm
Originally posted by MNLonnie MNLonnie wrote:
Should be 9.00X10.
....and expensive!
ALLIS EXPRESS!
This year:
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 10:39am
M.E.  miller tire
900-10   3 rib    $250
900-10 rib   implt $170
tube $24
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 11:48am
And don't even try to dissassemble anything on the rim components without letting ALL of the air out . . . . .
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 11:58am
Well where are you located and how much for a gear box? Don't need the single front wheel set up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 4:14pm
Am I correct in saying that gear box is the same for a single front and a 3 bolt wide front?  Ray is in NE Kansas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 6:24pm
Lonnie the front gear box are the same. You just unbolt the cast part the tie-rods bolt to on the bottom plate, then bolt the fork on.
