plowing with a C.A.
gh-in-oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gh-in-oh Quote  Post ReplyReply Direct Link To This Post Topic: plowing with a C.A.
    Posted: 10 Apr 2012 at 8:20am
IS there an adjustment on a c.a. to control the hydrolics while plowing?   In the past, when i would hit a hard spot in the soil, the plows would lift up a little on there own.  Kinda like a traction booster.   Now for some reason, the plows seem to want lift up all the time.   Causing a terrible jerking to the tractor.   If anybody has any suggestions, i would really appreciate your info.  Thanks for your time.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 9:34am
get a ca operators manual. money well spent.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 10:15am
You need one of these:
"Operating Instructions and Repair Parts Illustrations"
Gary
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2012 at 10:05pm
there are several adjustments that need to be made to the pump to have the traction booster work properly. Once you drop the plow, if you pull the lever part way up the traction booster should work. If you pull it up too far the plow will lift too much. The original battery box had a decal showing the positions of the screws on the pump. You want to set it up for "Drawbar control". Turn screw "A" out until it is free from the body( on short lever) turn "B" into body separating plates,( on the control lever at top of pump) turn "D" out as far as possible( located on the front of pump) screw "C" (on top of the body)  may be in any position, but best to turn it out against the stop. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote gh-in-oh Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 6:45am
Bob,
Thanks a million.   Remembered it being something like that.  But its been so long, I was second guessing myself.    Thanks again and will see what happens.
