model 80R sickle mower
juniorp53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Topic: model 80R sickle mower
    Posted: 08 Apr 2012 at 8:29pm
have a chance to buy a 80R sickle mower but live to far away to just run down and look at it .... was wondering if anyone knew how much this thing weights...and if it will fit into my pickup with out taking it apart  thanks -Joe
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 8:31pm
It will fit in a pickup. Make sure it has the bracket to attach to your tractor as many I see often dont have it. Ryan
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 8:32pm
i think the wt. is around 600 lbs and yes it will fit in a pu bed.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 8:59pm
600LB .. yikes guess i wont be horsing that into the back of the truck by myself! how much work is it to take apart?
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 11:42pm
the base wieght is just over 400 lbs. + 125 lbs. for a 7 ft. bar. your best bet would be that the guy you buy it from has something to help load it for ya. maybe a loader or come-a-long on a big tree branch.
been there done that, not doing it again...
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2012 at 7:27am
It's doable in a pickup -- but loading and unloading is not easy without equipment or a hoist , come-along and some kind of onverhang to attach to. They are kind of unwieldy because the bar wants to tip it it that side. If you can get a low trailer with a fold down ramp you can slide it out fairly easily. Is it 3point or snap coupler? If SC - like Ryan said, see if seller has the bracket that goes on the tractor -- What kind of tractor? the bracket is different on the D17 and D14.
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2012 at 10:10am
i have a trailer i was just hoping i wouldnt have to use it, it appears to be a snap coupler so i will make it a point to get all the parts that go with it. i have a d14 but its in pretty rough shape and was hoping this would work on my WD45D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2012 at 10:55am
Should work just fine on the WD45D --- the bracket you need is the one that attaches to right axel and has piece that hangs down to attach to the mower- many sellers forget that
it is still attached to the tractor when they sell the mower.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2012 at 1:20pm
Just to clarify some of the above comments:
If it is a Model 80R mower the tractor hitch does not actually attach to the Snap Coupler that is under the transmission.
The tractor drawbar is removed and a special hitch attaches in it's place using the 2 drawbar pins.
Then the left and right frame arms of the mower attach to this hitch.
The bracket that attaches to the R/H axle housing with 2 bolts is for the mower balance spring.
This spring  carries most of the weight of the mower when it is lowered in to the cutting position, thus reducing wear on the skid shoe located under the 'Twin Wheel Drive' Gear Box.
Hope this helps.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2012 at 1:49pm
If it's a snap coupler, it's not an 80R, it's a #7. I have a #7. It's a lot of weight to hang on the back of a CA.
This page was generated in 0.262 seconds.
