Decal Help!!!
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Topic: Decal Help!!!
    Posted: 07 Apr 2012 at 9:46pm
Ok, when I look at a lot of the B's and C's on here they have large decals on the side of the battery box, however when I look at buying decals they only sell the battery box decal with the CA sets. So should I just buy a CA set to for the decal, or does that decal not even belong on the B's? All advice appreciated, Thanks!
1950 B, 1952 pulling wd, and 1954 wd45
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 10:17pm
http://www.oocities.org/wackerdecals/You can check with Lyle Wacker for a set of decals.  http://stores.djstractorparts.com (David Stockbridge MI) as well as some other vendors on this site.
Edited by irlbeck A-C'S - 07 Apr 2012 at 10:26pm
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2012 at 10:21pm
Since that decal would be the one detailing how to setup the pump for traction boost, and the B and C do not have the boost, it would be completely incorrect to place it there.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 7:34pm
  not used on the B-C TRACTORS   lost cause    1-574-342-4545
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 9:30pm
A lot of kits had a B or a C that people put on the radiator shroud too. The C never had a decal there and the B didn't till after the CA came out.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2012 at 11:47pm
Charlie is correct. We leave it in the kits though becaue customers expect it to be there.  Same with the air cleaner oil level decal.
JimD
