FREON QUESTION
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: FREON QUESTION
    Posted: 04 Apr 2012 at 9:23pm
HELLO
  ANYONE IN HERE EVER CONVERTED A R-12 SYSTEM ON A 70 SERIES TO 134A ? IF SO DID YOU CHANGE THE EXPANSION VALVE ? IF VALVE WAS CHANGED ANY SOURCE AND PART # WOULD BE VERY HELPFUL, ANY OTHER TIPS WOULD BE VERY APPRECIATED .
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 9:36pm
Have converted alot by putting adaptors on lines and a new receiver dryer.   MACK
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 9:40pm
No, you don't need to replace the expansion valve. Actually, there are now some reasonably priced replacement alternatives for R-12, rather than converting to 134
I am still confident of this;
Wait for the Lord;
dad2many View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 9:44pm
The drop in replacements for r-12 a very reasonable compared to market price for 134a now. With the conversion the charge quantity is different and the valve ports need to be change. Other than that not a big deal.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 9:51pm
Anyone need any R12 - I have 3 cans here....
ALLIS EXPRESS!
This year:
DouginIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DouginIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 9:08am
Eldon, I sent you a PM. Doug
Moonlighter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moonlighter Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2012 at 11:10pm
Has any one heard of Red tec read about it never used it someone said it might be dangerous like anhydrous any ideas.  Seems much cheaper
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 6:59am
google up Freeze 12
That is what I put in the neighbor's R 12 farm systems.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 9:11am
I have a can of freeze 12 sitting on the shelf.  Let me know if someone needs it. I would have to lookup a fair price.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 9:12am
We could get it wholesale, but I was told it was stopping production so I bought what I could.  The 1 can is all I have left.
I should also mention, I can get very reasonable prices on tractor AC parts.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 9:29am
put 134 in it with a oil additive to make the mineral oil compatible and donnt look back. Some of the blends leak one blend more than the other and can't be toped off . So if you have a miniscule leak every season youll have to put a full charge in instead of a oz or 2 .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DouginIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 3:54pm
Where can you buy the mineral oil additive? Is it a Brand name or what is called? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 4:18pm
The automotive parts stores like oriely or autozone in this area have it. It comes in a black tube you screw it onto the schrader valve fitting then turn a nut with a socket on the back to compress the additive into the system. I think its PAG oil  from memory but not a 100 percent certain just  ask a good parts guy  with the info I posted and he should be able to get you hooked up with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 5:14pm
actually, I've evacuated and recharged several systems w/R-134 and nothing else, and so far, have never had a problem. Mitch does bring up a point, though, systems designed to run w/R-12 will quite possibly require occasional top offs as the R-134 molecule is much smaller than the R-12 and will sneak out of places that the R-12 couldn't
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 5:19pm
I need to clarify that a little refrigerant blends will need the whole charge put in everytime with a leaky system . single component refrigerants like 12 and 134 can be topped off by adding a oz or 2 . if thats all that has leaked out. Blends not the case. heres what i was meaning according to Technical Chemical freeze 12 is 80 percent R134A and 20 percent hcfc-124B  so when it leaks out is whats left the 80  percent 134 or the 20 percent r-124b who knows.
Edited by mlpankey - 06 Apr 2012 at 5:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 6:17pm
good point Mitch.
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 6:25pm
PAG oil is what all automotive systems run except for hybrids. PAG can cause a loss of isolation so POE is used. I've converted many 12 systems to 134 with only new valves and evac and recharge. In most cases 80% of the R12 capacity is what R134 charge ends up being.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2012 at 9:49pm
Originally posted by LouSWPA LouSWPA wrote:
good point Mitch.
Thanks Lou I am sure they will be two yahoos posting to attempt to discredit my post but thats life . Brian also added a good  point about the 80 percent less .I will say that in order to get 80 percent to work for me the low pressure switch had to be changed from the r12 to a r134 low pressure switch or I had to over charge with 134 a tad over 80 percent to keep compressor from cycling .This is basically how the freeze 12 works the 80 percent 134 with the 20percent hcfc -124b runs the same or as close as you can get to pshycometric curve as pure r12.
Edited by mlpankey - 06 Apr 2012 at 9:55pm
