Plow D17 mini pumpkin patch pics
CTD03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Topic: Plow D17 mini pumpkin patch pics
    Posted: 02 Apr 2012 at 8:59pm
I was tring to make a video but darn things are way to hard to make so looks like I will be just posting pics of what I am doing with the d17 this pumpkin season.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 9:02pm
Nice!  After you clean it up, take a good very close up pic of those decals on the moldboard of your 63 plow.  Very few AC plows have decals left that readable anymore.  They even have the part number? along with the bottom number.  I like the belt pulley on your D17 too!.  Mike
Edited by Skyhighballoon(MO) - 02 Apr 2012 at 9:03pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 9:05pm
THAT RICH BLACK EARTH!!  Sure beats red clay rock.
D-17 looks GREAT!!
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 9:07pm
I am not really sure what I am doing with the plow. I was tring to get it set right but the tractor isnt running its best. I plowed in 2nd low then switch to 1st high.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 9:33pm
looks great  where at in pa are you  it looks a little more wet there than my place.
      Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 7:18am
1hr and 30 min northeast of you. The ground was a little wet.
b170dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b170dr Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 1:09pm
Looks like  good ground.  You need to set your  wheel in a hole or two. Mite have to move plow  on shaft up front, to make pull straight. Should be able to unhook the lift arm latches and plow run perfect if everything is set right. They will float through like a walking plow behind a team of horses. Just play around with it. There a fun  plow to work with.  Roger.
'64 B-10, '58 D-14, '60 D-15D, '58 D-17D, D-19, 170, 2-185D, 190, 68 D-21 11, 72-220, 7000,7030, F-2 G,w/5 Heads,L-2 G, 330 No-Till
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 3:35pm
very sound advice roger. will be doing some test plowing tonight here around wooster, ohio to set the depth wheel and align the plow using the the front channel bar on our 4x16 sc. d19 setup.....best regards. tp studer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 7:39pm
so maybe up around sandylake area ??
 Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 7:55pm
that is great info I will def try this. It was bothering me cause really i am just newb at plowing.
will i need to run the back wheel in also if i run the front in one or two more holes. I may have to make the patch bigger just to see if it works.
Post Options Post Options   Thanks (1) Thanks(1)   Quote b170dr Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 12:02am
Move both wheels. Set front wheel so it runs in the middle of the back tire tread.  I mever had a three bottom with a land wheel. On a four bottom plow you need to have the tires set  out some.  When the rear tire is along the side of the forrow,measure and you should be cutting 14 or 16 inch what ever your plow is.
Then ajust plow on front shaft so it pulls straight. You shoulkd beable to unhook the lift latches. they should have nothing to do with holding the plow in line.  Just keep playing with it.  Roger
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 6:36am
dad(bolivar boy) and i where in the barn last night, intentions where to adjust that bar on the front, (thanks for the info roger) it needs to be slid the opposite way than the d-17 in the pics in this post. needless to say  the fasteners probably havn't been turned in 40 years. dad broke 2 loose, broke the head off one and the last one was broke off flush and we drilled it out so we can use an eze-out. a little heat today and some hardware and we  should be able to carry on with our adjustment procedings. hopefully everything goes ok, saturday looks like a nice day for field work.  pete
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 6:47am
Nice plow -- have not seen one that had still have decals like that. Pumpkins are fun to grow.
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 8:55pm
This picture looks like the furrow wheel is about  4-6 inches to the right of the landside of the furrow. The first bottom looks like it is only cutting 10 inches. Looks to me like if the tractor was a 5 inches to the left the first bottom would be cutting the full width. Now I'm no plow expert but I did turn a lot of by the age of 15.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 8:58pm
I'm sure the pumkins won't mind any of thisLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 9:15pm
any help would be great.  I dont mind them helping out at all.
The pumpkins will not mind it at all but I would like to learn how to setup the plow. Witch all you guys are helping me out. I think i may go turn up some more just to play with what I have learned
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 9:17pm
tractor is over to far but I am just posting it
Edited by CTD03 - 04 Apr 2012 at 9:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 9:35pm
My point was, it doesn't look to me like you right wheel needs to be moved in. If you drive in the furrow next to the cut, your plow will cut a full width. If you drove to the left a little the dirt turned by the first bottom would also cover you wheel track.
 I also think the lift links would hang different if you drove only in the furrow instead of on top of turned dirt.Sleepy
Edited by CTuckerNWIL - 04 Apr 2012 at 9:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 9:42pm
I never plowed with a wide front tractor but I have seen guys turn their front to the left so let the right front wheel tries to climb out of the furrow, let go of the steering wheel and go all the way across the field without touching the steering wheel again.
Rich--MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich--MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 9:51pm
Dang..your pics are giving me the "itch" to put my snoring D-17 to work.. Son went up last week and used the WD to move some stuff around and cut pretty deep in the heavy clay with the narrower tires..guess I'm going to have to wait a couple more weeks !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2012 at 10:00pm
I do agree wasnt saying your post was wrong just showing what I was doing to learn and sure hope to help others that dont do this or maybe picking up plows. trust me i will be going out to set my plows to run like they should and be putting pics up. vids take to long for me to make.
Edited by CTD03 - 04 Apr 2012 at 10:03pm
