Gasket (belt pulley tube wd)
Bob wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob wi Quote  Post ReplyReply Direct Link To This Post Topic: Gasket (belt pulley tube wd)
    Posted: 31 Mar 2012 at 9:04am
Ready to install the new cork gasket between the frame and housing for the belt pulley tube/cover on the wd do I soak it in oil first or install it dry
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 9:10am
Bob,
I pressed mine in dry and it never sealed right. The next time I intend to soak it up first. I ended up making a bracket that mounts on the three bolts surrounding the cap with a strap across the cap to slow the leak. Probably should have gotten a new cork!
