7060 steering problems
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: 7060 steering problems
    Posted: 28 Mar 2012 at 8:01pm
The 7060 was out doing a little plowing today.  That in its self should be news since we have not moldboard plowed two years on a row since I have been farming.  Anyway to the point of my post the 7060 will intermitently not steer.  The steering wheel turns fine but nothing happens.  Oil levels are fine, it doesn't matter what way you turn the wheel.  The only pattern the was noticed that as you come out of the forrow it will turnfine as you turn the wheel back to straighten out nothing happens. If you give it a quick jerk back to the opposite direction then try to straighten the wheel it will turn fine.  Any thoughts ????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 10:30pm
Sounds like it is in steering motor. Broken centering springs maby. MACK
