ca/b/c gas tank.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: ca/b/c gas tank.
    Posted: 27 Mar 2012 at 6:57am
Is a ca gas tank the same as a b or c?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 7:01am
CA and late B shared a tank I believe. The CA had the starter switch on top so there is an indentation in the bottom of the tank for clearance. Not sure if any C's had this tank. Older B's and C's did not have this " inverted bump". Early B's didn't have the strap on the back end of the tank for a mount bolt.
Edited by CTuckerNWIL - 27 Mar 2012 at 8:04am
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 10:07pm
Late B/CA tanks will work on Cs and earlier Bs except for the very early Bs. But none of the Early B/C tanks work on the late Bs & CAs. Kip
