D15 charging system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: D15 charging system?
    Posted: 26 Mar 2012 at 7:22pm
 My D15 wouldn't start. Nothing at all, tried to jump thru solenoid, barely a buzz, battery flat. I charged the battery,started fine. When cranking it will show a discharge. When running will not show charging. Is it the generator or voltage regulator? How do I check it to find out? Thanks Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:01pm
You can test the gen easily. Remove the belt, disconnect the wires, and run battery voltage to the A terminal. It should spin like a motor. While motoring, ground the F terminal to the case. It should slow down, but continue to motor. Load test all of your wires by using them in a circuit to power a headlight bulb. If the wires and gen pass, the regulator is all that's left.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:39pm
Brian, I will try that method. Thanks for the help. Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:56pm
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 9:21pm
Never done it like Brian described, I always run the engine at half or so throttle and ground the F or Field terminal. You should see the amp meter jump to full charge. This too shows the generator is good or not. 90% of the time I find either a stuck brush or corroded brush holder or a bad regulator. Most of the new regulators are china made and the metal rivets on the bottom rust soon after installing it and it fails. IF you determine a faulty regulator I'd pop the cover and buff the points and check them for sticking and so forth before replacing. You might get lucky and keep a better one than you can buy.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 5:29pm
Here is everything you need to know on generators - delco service bulletin
