Allis B Engine Sleeve install
rellis73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rellis73 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Engine Sleeve install
    Posted: 26 Mar 2012 at 6:32pm
Hey guys!  Got a question.  I am working on a 1952 Allis B and am in the middle of rebuilding the engine, starting to put it back together.   I removed the old sleeves and cleaned the block thoroughly.  The old sleeves had what looked like flat o rings (or they could have just been that worn) but the new sleeves came with round o rings.  I'm not as concerned about that as I am that the sleeves have two grooves and the kit came with three o rings.  Also the o-rings are rather "loose" in the groove and one groove will hold two o rings.  Does anyone know why the kit came with three but the sleeve only has two grooves and should I be concerned about how much clearance the o ring has in the groove?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 6:46pm
The kit I bought last year also had an extra o ring for each sleeve, don't know why. I just kept them for future use somewhere else.
Waukesha B, B, IB, G, styled WF, D17, 615 backhoe, 2-Oliver OC3's, 5 Ford Model T's, 3 Model A Fords, 34 Ford coupe, 57 T-Bird
Post Options Post Options   Thanks (0) Thanks(0)   Quote rellis73 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:05pm
Did your o ring also have a lot of play between the top and the bottom of the groove?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:09pm
Couldn't tell you for sure, the machine shop ordered the kit and installed the sleeves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rellis73 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:13pm
Ok.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:12pm
The reason the O rings were flat is that they took a (set) (the shape they were pressed into) over time. You would use one O ring per groove. The thing to be concerned about is how much larger the outside diameter of the installed O ring compaired to the outside diameter of the sleeve beside the O rings.  You need enough press of the O ring to seal.
Remember that the sleeves should be able to be put down in the block all the way and turn 360 degrees by hand without the O rings to make sure they will set flat at the top lip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rellis73 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:21pm
Thanks so much!  That is what I was wondering!
DennisK (/WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisK (/WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:41pm
I would get a hold of the supplier and ask what's up.  I find it hard to believe they would just send extra o rings and two in one groove doesn't sound right either.  As already said the originals were probably round when installed.
This is a critical area for your rebuild and would want it right.
Just my 2 cents
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:51pm
I buy the O rings for the standard sleeves 50 at a time.  If the ones you do not seem to fit send me a PM. I just receved a new batch a coupla weeks ago.
