Run fine and quit
Rich Steiner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Topic: Run fine and quit
    Posted: 24 Mar 2012 at 8:16am
All...
I have a problem with my B.  It will start up nice, and run and idol.
But after about half hour it will quit.  The motor will sputter a little and then just shut down.  I can restart it okay and it will run fine.
If I pull the choke out all the way,  sometimes it will run better.
My other B will do the same but seems to be worse.  After about a half hour it will start to do the same thing.  I will restart it and it will run for about 5 min and shut down again.
Is the problem Mag,  Carb, ??????
Thanks
Rich
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 8:38am
If it runs better with the choke then it sound like some type of fuel restriction to me. It could be in the carb, sediment bulb (check the screen) or something in the tank.
Just some suggestions, I'm sure there will be more.
Pete
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 8:52am
I'm agreeing with Pete. Probably have crud in the tank that takes a while to plug up the tank outlet fitting. Turn it off and the suction ceases and the crud releases back into the tank.
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 9:37am
Air vent on gas cap could be plugged, run it with cap loose to check.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 10:43am
I went thru this battle about 2 years ago on my B.  After not being able to solve it in the ignition system, I sent the carb. to Steve at B & B ( who is a vendor on this site) and he cleaned and rebuilt it and when it was returned, It worked perfect and never had a cut-off since.  I could almost time it cutting off at 45 minutes.  I'm  sure you will have other post, but would bet it is in the fuel system.
Life is what happens while you are making plans for the future
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 10:51am
If choking helps, its almost sure to be fuel starvation. A coil or condenser heating up won't recover rapidly.
A fuel restriction can be anywhere from the screen in the tank to the float bowl. And there can be multiple restrictions in the vintage tractor. Junk in the tank can float to that screen above the shut off valve or sediment bowl. The screen in the sediment bowl can be nearly plugged with varnish and dirt. As can the pipes. Most carburetors include a screen on the inside end of the inlet adapter and that screen is notorious for plugging. I've seen one plugged so solidly it wouldn't pass air at 60 psi. Then there's a sticky float needle or float and the gas gap that's not venting. The gas cap though will shut down more rapidly with a full tank than a near empty tank.
Besides running a long time a good check is when the float bowl has a drain plug. Pull the drain plug and there should be a steady stream of gasoline about the size of a pencil in diameter for as long as there's gas in the tank. Any less shows a restriction to be found. Don't smoke while doing this test.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 11:35am
Thanks guys
That is what I'm thinking it is the carb...
Rich
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 12:00pm
Bet the problem is between the carburator and the gas cap.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 12:16pm
Well fellas I had a chance to work on my B this morning to see if I could fix the problem.
I took out the old Champion plugs that were in there (Dad put them in there) and replaced them with AC 303's.
I cleaned out the sediment bowl.  It had a lot of dirt in the bottom.
I cleaned out the air "cup" and put new oil in there.
Started her up and it seemed to run great.  So I though I'll try mowing with it.  I have a Woods belly mower under it.  Started out good.  and then all of a sudden it quit.
So I got the crank out gave to cranks and it started right up.
I went another 20 feet and she quit again.  Hmmmm......So I got the crank in her and she started right up.
So what do you guys think I should next.  I didn't want to take the carb off until I was sure I can get it back on and not have any trouble.  It seems to run but then for no reason it will cut out...
Thanks
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 12:23pm
Remove the drain from the bottom of the carb bowl and see if you have fuel flowing free for a minute or two. You may want to catch this and please don't smoke:) If the fuel slows down or stops, you have a restriction somewhere between the float seat and the gas tank. If it flows free, you have a problem in the carb itself.
BoBMeL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BoBMeL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 12:49pm
Had a similar problem on my d 12 it ended up being a nozzle in my carb it looked like you took a knife long ways down a straw replaced that and took pea gravel to my gas tank and then shook for a while cleaned it out let it dry out. Put some sea foam in the tank and ran it wide open for a while and haven't had a problem. That was a year ago hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 3:37pm
Okay.....I opened up what looked like a "wing" nut on the bottom of the Carb.
I had flow for just a little bit and then it just bubbled a little and flow was really faint.
So I opened what looked like a bolt in the bottom and got a good stream for about 20 seconds.  Then it just trickled a little.
I don't know if I was imaging things but the gas looked dirty.
So how hard is it to take the carb off and clean it.  I am afraid of losing my settings on the pin valves (idle and such).  Or do they stay set when you drop it down from the manifold.
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote BoBMeL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 4:02pm
What kind of carb do you have, if its a zenith model they are easy to remove and take apart ive done it on mine a couple of times also make sure you check your fuel line and back itright have rust in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 4:09pm
Bob
I think that is what it is.
Do you suppose the copper line that comes from the sediment bowl has restriction?
I never took one off but I am willing to give it a try.
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote BoBMeL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 4:29pm
Yes sir if it is a copper line of pull it off run some cleaner through it and maybe if your AChas a sediment bowl I'd clean it out real good. I use seafoam. Fuel additive sold at any auto parts store or walmart. Also my grandfather told me that due to the shape and thickness of gas tank, not to leave in llsudirec
t sun due to evap and condensation. Don't know if true buton
Post Options Post Options   Thanks (0) Thanks(0)   Quote BoBMeL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 4:30pm
Don't know if its true bit it works for me I hope this helps if you need anything else let me know glad to help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 4:37pm
Thanks Bob
Anyone else have any encouragement....
Rich
George R. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George R. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 5:29pm
Rich,
Shine a flashlight into your gas tank.  Sounds like a lady bug or muddabber is plugging up the fuel line....a friend of mine had a problem similar to what you have described on his old C he  uses for mowing.  After he replaced everything he could think of his neighbor shined a flashlignt into the tank and lo and behold an asian beetle was plugging the fuel line at the tank!
My tractor is not leaking oil, it's just marking it's territory!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 5:39pm
Rich
Don't worry about taking the carb off until you have a good flow of gas to it. If you don't have a solid stream running continuously from the carb drain, you have a blockage somewhere between the float seat and the gas tank. First, is the sediment bowl shut off opened? If it is start by taking the gas line off at the carb and see if you have a good flow of gas from the tank to the end of that line. If not, follow it back and find the obstruction. If you have good flow at the carb fuel line, you may have something in the carb itself but check the flow from the tank first before you pull the carb off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 6:02pm
Thanks guys I'll let you know how I make out tomorrow.
Rich
I am also going to see if I can get some oil in the spark plug holes on my other froze up B.
Always something....
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 6:05pm
There is a screen usually on the inlet pipe adapter to most carburetors. It often gets plugged by varnish and dirt. Next check, unhook the fuel line from that fitting and see if you get a good flow of fuel. Lines can be filled with varnish and dirt to the point very liss gas will pass just like screens and tank inlet. Lines can either be replaced or reamed with a wire and carburetor cleaner solvent. Didn't I say all this last week?
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 6:56pm
Sorry Gerald.....
I forgot that you posted.  I need to get my head out of my ....
I will try to see if there is good flow.  I have a couple of tractors that are doing this...
Will let you know..
Thanks
Rich
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2012 at 7:39pm
I have had a similar problem with a CA I recently purchased. This ethanol blended gas we use now will mess up a carb if it sets too long. Be sure to treat your gasoline with sta-bil. It seems to preserve the gas for a year or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 12:07pm
Okay,  I did what you fellas suggested and I had good flow in the fuel line
So I took the carb off, and cleaned it with carb cleaner.
There was a good amount of crude in there,  especially where the air cleaner hooks up to the choke.
Got it all cleaned up put it back together,
Started it up and it really ran good.  No misses or nothing.
So I thought that did it.  Started mowing and it quit.  I tried to start it and it would not start.  Then it would run and quickly quit.  Like it was out of gas.
1.   Would the float be not opening?
2.   There is a spring on the rod that controls the throttle by the carb.  One end is hooked to the rod and the other isn't hooked to anything.  Were does that spring hook to?
Thanks
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 5:54pm
Float can be dragging on the side of the float bowl, but I BET its that screen on the inlet fitting. Been there.
Gerald J.
AL35U View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AL35U Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 8:16pm
Start at the tank and work your way down.  Just from experience I'd bet you find it before you get to the carb.  Gerald's probably right, the screen on the inlet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 8:59pm
How long did you let it run? If there is something in the tank floating around, it might take 10 minutes before it plugs the outlet. I had a guy put gas in the CA once with a Clorox jug. The little cardboard gasket from the lid got in the tank and gave me fits till I found it. You never knew when it would run 10 seconds or 10 minutes.
Did you take the nozzle out and clean it? How about all the little passages in the carb, they all need to be clean and free of any loose particles. Did you clean and inspect the inlet where the fuel line hooks up all the way through to the float seat?
Right there you need to immediately remove the drain plug from the bottom of the carb bowl to see if you still have fuel.
It's possible but I would say not likely.
The other end hooks to a manifold stud. this is called the anti surge spring and would have nothing to do with your engine dieing.
Do you have the original steel fuel line from the sediment bowl to the carb? Some people replace this with a rubber hose which can cause problems and some add an in-line filter which can cause more problems if it isn't for a gravity flow system.
Edited by CTuckerNWIL - 19 Apr 2012 at 9:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 11:15pm
A good test for float needle and seat with the carburetor off and partly disassembled, is to blow with mouth at the fuel inlet. (cleaning makes it more pleasant). With the top half the carburetor right side up, gently raising the float should stop air flow and lowering the float MUST allow air at lung pressure to flow. Worn and new needles have been known to stick. Worn ones from wear, new ones from a rubber tip. That also checks the screen I keep harping on. A second check can be made with the top of the carburetor upside down. Same pressure source (lung) the weight of the float should shut the needle valve solidly, but lifting the float a little bit should allow lung pressure to pass, though it may take a bit more pressure to lift the needle when its not hooked to the float arm.
Simple tests that take no special test equipment to check for flow with little pressure and for flow shutoff to prevent flooding. Floats tend to stick down more than up, but floats can also not float because of leaks. But that causes the engine to flood and it doesn't start. Usually just sitting with a float not floating the float bowl overflows. Different symptoms.
On a neighbors, JD 2020 that screen would only allow enough fuel to get to the carburetor to run for a few seconds and then only if choked to the limit. Happened on a day when I had borrowed it and him to prune a walnut limb hanging over the LP tank. When I took out the screen fitting, I couldn't blow air through the screen with the 60 psi air in my portable air tank. He couldn't find a replacement so we ran a drill through the screen while JD delivered a new screen in a few days, and then the tractor ran fine. CHECK THAT SCREEN!
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich Steiner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 6:52am
Gerald.....
Thanks for the info.  I forgot the screen!!
Were the intake is there is a 90 degree fitting.  Does this screw off?
I am going to try this anyway....
What about the spring hooked on the rod.  I have been running with out it for years I guess.  I never saw it until I took the carb off.  I guess I really don't need it hooked up.
Will try those things and let you know...
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2012 at 7:43am
Usually the screen is on a straight fitting that the elbow attaches to. Take off the elbow, then unscrew that straight fitting.
Gerald J.
This page was generated in 0.104 seconds.
