WD45 ENGINE GASKET SET
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 ENGINE GASKET SET
    Posted: 23 Mar 2012 at 8:50pm
What is the correct part number for wd45 226 in gas engine gasket set. I want the complete engine gasket set. Was looking at the Agco numbers. They list different sets before & after number 289000. Is that the engine number? Mine is a 1954 model & the engine # is 45-34415-G. I think the only important part is the middle part 34415 so that 289000 doesn't seem to make sense. My tractor serial is 175421.
Thanks, Ed.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 11:24am
Beginning with WD Engine #289001 (sometime in '51) the WD was equipped with the 4" "tall" head which continued on with the WD-45s.
Unlike the Tractor numbers which continued from the WD thru the WD-45,
the Engine numbers started anew with the WD-45s.
However........I would interpret the parts manual to mean all WDs after Eng #289000 and all WD-45s would use the newer gasket set.
I have an aftermarket gasket set and I believe there are enough gaskets in the set to
meet the requirements of both early and late model engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 4:45pm
Thanks a bunch Brian. That makes it all make sense now. I didn't realize that number break was for the WD engine. Smile Now to get the set and get to work!!
