200 cab on a 190 - picture
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: 200 cab on a 190 - picture
    Posted: 23 Mar 2012 at 7:11am
Here is a picture of my latest project.  I bought a cab off of a 200 from Ilgleaner and mounted it on my 65' 190.  Fits it like a charm.  I do have to figure out why I have an opening on either side of the platform (right at the front of the platform) and why I have a gap on either side of fuel tank.
Adam
Edited by Sandknob - 23 Mar 2012 at 11:33am
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 7:43am
Don't worry about the gap Adam. Cut up a couple gallon vegtable cans, flatten em out and cut to size. Walla, no more gap. LOL
lbr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lbr Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 12:31pm
What did you use for sealing around the hood and the cab?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 12:36pm
Just the factory rubber pieces.
Adam
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 2:14pm
Nice job Adam!
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 7:03pm
There is a gap on either side of the fuel tank normally. How much are you talking about. Maybe 2" or so? at the front of the cab the floors might be different cuz of the battery box top on one side, not sure about the other.
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 8:02pm
The 200's had a filler plate that goes on the floor on both sides at the front. You are missing those. The gap at the back by the fuel tank had like a 2" piece of foam on each side to seal it up. I think the platform on the 190 series 3 was the same as the 200.
Edited by amac - 23 Mar 2012 at 8:04pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2012 at 8:04pm
There is a foam piece on either end of the fuel tank to fill the gap. I used some foam pipe insulation on my 200.
There are sheet metal closeouts that fills the front on the floor. They bolt to the cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:11am
I found where I had stashed the shields so now I need to get them put on.  It is a bit louder than I had expected, course that could be due to the shields not being in place.
Adam
Was there a rubber floor mat that came with these?
Justin Widlund (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin Widlund (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:00pm
Yes.  I know www.hy-capacity.com have replacements for the cab floors.  How hard was this to mount?  Did you use a loader tractor to help set it on?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:38pm
Is this cab isolated by rubber mounts like a 7000 series?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 9:39pm
I might also note that there is a panel under the hood below the dash panel on the 200.
There is insulation on top of this panel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 7:37am
Cab was not hard to mount.  It uses two braces that extend from bellhousing back to rear axle.  Those mount first.  Then the cab just sets on those.  I borrowed a boom truck our company has to set it on there.  I don't think that a loader would lift high enough.  Joe, what does that shield look like (behind the dash)?  I don't happen to have it and I noticed there seems to be a lot of noise from that area.
Thanks
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 8:37pm
The cover is made of 2 sheet metal panels. They are called deflectors in the parts book
They attaches to the cross brace on the hood and to an angle part attached to the dash support brace.
In the agco parts book for the 200 under sheet metal, pg 126, item 13 and 14 and item 5 on page 118
This page was generated in 0.095 seconds.
