Need a new clutch
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Topic: Need a new clutch
    Posted: 20 Mar 2012 at 8:19am
Need a new clutch for a D19D What is the best one to put in? I have had trouble with 3 different D19s slipping the main clutch
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 12:46pm
 Are you  running a rag  clutch  or a button clutch ??  Are you surfacing  the  flywheel ??  Are you adjusting  the  fingers correctly ??      is  the release  bearing  clearance  set up  right ??     Are you sure it`s  the  master  clutch ??       Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2012 at 5:36pm
Use a 170 or 175 clutch disc (4-button) and sure flywheel drpth is 1.437" or a bit less.
