Cultivator
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Topic: Cultivator
    Posted: 19 Mar 2012 at 7:06am
Anyone ever use one of these as a cultivator?
1944 Allis C
1960 Allis D-17 LP
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 12:43pm
Looks like a Pittsburg brand. I have 1 like it. Haven't used it as a cultivator but I don't see why it wouldn't work. Because the shanks are mounted on angle iron that has holes the whole length it would be fairly easy to get the correct spacing. My concern would be  there isn't alot of clearance front to back so if you're in some weedy crops plugging could be an issue-unless you try to run only 1 shank per row with a wide sweep, kinda like a min-till cultivator. Same goes for height clearance. You going to need a coulter or some way to keep it from drifting off the row.
Just a couple thoughts.
Good luck.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 1:05pm
Those were made for seedbead preperation, not rowcrop work.
