welding on a 45 diesel block
Maurice/Pa. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maurice/Pa. Quote  Post ReplyReply Direct Link To This Post Topic: welding on a 45 diesel block
    Posted: 15 Mar 2012 at 4:31pm
 Where is a good machine shop in Pa. to take a wd45 diesel block for welding the cracks shut?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 7:27pm
Not sure of any in PA, Have 2-3 noted in addy book of reputable shops refered by other Forum members, can post here if needed. After you get estimate, you may want to consider the block I here to sell. I do not see any cracks, and liners actually stand proud to top block.
Edited by Chris/CT - 15 Mar 2012 at 7:29pm
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 7:50pm
chris what are you asking for that block?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maurice/Pa. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:25pm
 Cris, I would be interested,give me a call, 717 917 7981
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:44am
I realize this is 1/2 a country away but, if you do need a block welded or repaired I highly recoment these two places.  Both are located west of Chapin Illinois.  R & J Machine & Welding, 217-472-5121 or Chapin Cylinder Head & Block, 217-472-3333.  Two brothers with their own shops, the original shop was started years ago by their grandfather, then their dad.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 11:02am
Midwest Cylinder Head, Nevada Iowa.
Gerald J.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 5:44pm
Rutts Machine shop in Elizabethtown Pa
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 5:55pm
Midwest Cyl Head in Nevada can re sleeve the counter bores for the liners if need be. It was going to be about $1200 for them to weld cracks around 10 head bolt holes and sleeve the bores. I found a nice replacement combine block and ended up with $800 getting it in shape...
