185 repair ?'s
180man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180man Quote  Post ReplyReply Direct Link To This Post Topic: 185 repair ?'s
    Posted: 12 Mar 2012 at 9:07pm
another question for. I have a 185 diesel and my problem is that when I throttle up it start off will full fuel but then it drops in rpm like it's running out of fuel. When I bought it would run the fuel filter out of fuel and quit.
So then I notice a lot of crud in the settlement bowl so Clean the screen out and also blew out the lines and into the tank. Wow, it took rift off. So I started to disc with it, then about 5 minutes it started again. SO THEN I TOOOK THE FUEL TANK OUT AND POWER WASHED IT OUT, CLEANED IT OUT REAL GOOD. TONIGHT I FINISHED PUTTING IT BACK TOGETHER AND IT'S DOING THE SAME TING. BUT IT DOES NOT PUMP THE FUEL FILTER OUT. WHAT'S WRONG?????? I'M AT WITS END... THANKS FOR ANY HELP. 1180 MAN, NOT 185
