fuel injection shop (ont)
leoversteeg11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoversteeg11 Quote  Post ReplyReply Direct Link To This Post Topic: fuel injection shop (ont)
    Posted: 12 Mar 2012 at 8:26pm
Can somebody from the Toronto area recommend a good place to rebuild pumps+injectors.I am fed up with the shops here in the east.I have an 8070 with a hateful American Bosch pump.The biggest problem I have with it is the erratic governer.I  get it fixed , it works great for awhile, then the problem starts again. You have no control of the rpm's once you get over 1750rpm.It will rev close to 3000 if you let it.Sometimes you can shut the tractor off, and start it up and work for the rest of the day ,no problem.I know nothing about fuel pumps but have been told this pumps governor is controlled by oil pressure.Don't laugh but sometimes when I change the eng oil, the problem shows up instantly.Any advice appreciated.AngryAngryAngry
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 7:31am
I understand entirely how you feel.  I have had no luck with the pump shops near me and I am west of London.  I have and 8030 I bought at an auction in Alberta here for a couple years.  It has a rebuilt pump on it from a shop in Red Deer Alberta.  I have had 2 other 8030s and an 8010 and none of them ran like this one or started right for that matter.  I am sending my pumps to them to try from now on.  I have had two pumps right after rebuild (within a couple hours) literally self destruct and when I took them back they argued with me and said it wasn't their fault, both times they fixed them and wouldn't charge me for it, quit using them, next shop did the pump on my 210 and set it at 70cc, said right on the bill, ran it and it wouldn't pull nothing, looked in my service manual and it said something like 89cc, so I took it back, guy said my specs were wrong so I put it on the dyno, 101hp.  He set it right and then charged me for it, end of my business there too.  They are very hard to find some shop that is good and they all charge a lot of money for what they do I think.
pm me if you want the name and address of the Red Deer shop, it is the only placa I am sending a pump of and 8000 series by the way thai one runs.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 7:35am
Switch the AMBAC to Roosa or an Bosh. That's my thoughts but I have a good shop not far from me.
Wink
I am a Russian Bot
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 9:39am
My machine shop guy uses a place in Markham called Dale's. I will get the # for you.I have done a Canada411 search and cant find it. Don't send it to First Diesel in Belleville. PM me to remind me. Dale's also advertises in Ontario farmer.
Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Tony Elo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Elo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 4:35pm
I have dealt with these guys before,Mikes Fuel injection 519 748 5877,they are in Kitchener,we had him rebuild a pump on a 160 allis it worked good,don't know how he is for your pump,all you can do is give him a try
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoversteeg11 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 4:35pm
I would love to switch to a roosa, but then you have to switch injectors and fuel lines too,$$$$$$.My buddy sends his stuff to Sharma Diesel in Missisauga ,but he runs a dozen Mack trucks, nothing agricultural.Anybody heard of them.I get the ontario farmer,I will call that place and see if they know about the problems i'm experiencing.There's nothing worse than explaining to somebody what's wrong and you know they're not really listening and wont relay info to person who is actually doing the work.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 6:11pm
We have used these guys at work for rebuilt injectors and they have been good.
http://www.industrydiesel.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 6:34pm
There's a guy in Aberfoyle ( south of Guelph) that's supposed to be good....have to try to find his name......
Jay
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 8:48pm
Give Rovan Diesel, 309 Watline Ave, Miss a call
at 905 507 6003
Good luck
We purchased a new 8030 Aug 1984 and traded it in 2000. I pulled the
injectors once and had them cleaned at a shop in Alliston , Ontario
Smitty's
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
