pulling tractor weights
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Topic: pulling tractor weights
    Posted: 10 Mar 2012 at 8:12am
had an idea the other day...i have some suitcase weights that i use on my pulling wc, but not enough for all of my weight classes. for those classes i still have to mess with some f&h rear wheel weights, which take time to put off and on and weigh 142 lbs each.  in my older years they keep getting heavier and harder to handle.....but, i've got a bunch of f&h wheel weights, both 161 and 162 style.  they don't seem to be bringing much money to sell them, so i was thinking about cutting them in half, cutting a slot in them, and hanging them on weight brackets like suitcase weights.  would be easier to handle and a lot quicker.  they've got two big slots on the outside that could be used as a handle...only downside i can see is that they would be thicker than suitcase weight and would need more room on the weight bracket.  anyone ever tried this or seen it done??
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 8:42am
Are not 161 & 162 weights the ones that fit unstyled WC's and WF's rear wheels? Mybe someone on here would want to buy them from you, or trade. Just a thought.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 9:40am
161 and 162's fit all WC's I believe .....nothing special I know of.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 1:55pm
yeah, benny's right.  very common weight......f&h made them for other colors as well, look about the same but have different numbers on them......but i would gladly trade some for suitcase weights, could probably sell a set or so too.....
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 2:31pm
What do you plan to cut them with? Torch wont cut cast.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 4:31pm
A big bandsaw works well for cutting. You might also consider  cutting into 4,6, or 8 peices, whatever your comfortable lifting and build your rack to hold them accordingly.
I started out years ago with nothing.... after this divorce , I'll be getting most of it back.........
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 5:01pm
I have a set of each,161's and 162's. One set is painted Red and were on a Farmall, the other is painted green and were on an Oliver.
Edited by CTuckerNWIL - 10 Mar 2012 at 5:01pm
deereequipment1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 6:16pm
I have F&H weights on my puller.
I made a bracket out of a large piece of tubing (that fits the hole in the weights), that bolts to the rim, then I use one of those hydraulic jack lift arms (which I mounted on the front corner of my trailer) to pick up those weights, swing it around, then slide it up over that bracket onto the tractor. Then I just bolt them up tight, and ready to go.
It takes just a couple of minutes each weight, and saves the back!
Raised on a CA,WD,D10 & D15.
Now, proudly own and pull a WD45 high crop, WD45, WC,
also own a D-10, D-12, G and a CA.
