WD45 Hydraulic Hold Position
jyanna View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jyanna Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hydraulic Hold Position
    Posted: 09 Mar 2012 at 8:51pm
Been searching posts about hydraulic hold positions and now I am more confused.  I have a 3 pt on my wd45.  I cannot hold it at one position.  It wants to drift up or down.  Can I fix this?
Thanks!
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 9:28pm
WILL WORK   IF PUMP IS SET CORRECT   RECHECK SETTING   HAD IT HAPPEN ON A COMBINE ONCE   LOWERSCREW ON PUMP WAS NOT SCREWD INTO PUMP BODY
  FRON AN A-C MAN    DRAWBAR CONTROL ARM ACTIVATE IT WHEN PULLING UNIT
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 5:50am
Set the hydrualic control lever at the hold position with a load on the arms and shut the tractor off. If the arms stay in place, the linkage needs adjusted. If they still go down it's time for a new ball and seat in the hold position valve. This assumes that the pump is set to hold like Norm said.
This page was generated in 0.266 seconds.
