670t
DARRELL(PEI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DARRELL(PEI) Quote  Post ReplyReply Direct Link To This Post Topic: 670t
    Posted: 09 Mar 2012 at 9:43am
Located this motor, out of a 7045 and would like to know the good and bad of It, and will It fit Into a 220.Still looking for a good motor for the 220 and hope this works out, not much to choose from when dealing here on the Island. Thanks for any help on this.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 10:15am
Direct bolt in, no.  Will it work, yes.  Do you have the original 220 engine?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 11:52am
We're installing a 3500 MK II (same as 670T) in a 220 now. You will need to change the bottom rad inlet to the left side. Not sure about the front plate. My engine was a power
plant so we made mounting brackets for the 220 instead of changing the front plate which is a major job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 11:54am
One ong picture above.  Left side
Post Options Post Options   Thanks (0) Thanks(0)   Quote DARRELL(PEI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 12:45pm
so your saying the MK 11  3500 would be a much better fit, less time In fitting It In. I had a lead on a Mk11 In New Brunswick which Is on a gen set, so I am going In that direction until I hear other wise. Thanks Guys.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 12:52pm
Originally posted by Calvin Schmidt Calvin Schmidt wrote:
One long picture above.  Left side
So when you put a power plant in a tractor do you have to change the pump settings?
1944 Allis C
1960 Allis D-17 LP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 1:20pm
My engine was on a water pump and had 82 original hours. The book said it was an 'on highway' engine. It has a variable speed govenor so we're good to go. Luckily the front plate had the mounting for a compressor which is the same as a hydraulic pump. If the engine is from a combine it will not have that opening. Front plates vary depending on application. Since this engine already had the hydraulic pump mount, it was simple to change the mounts to the tractor frame. A 670T may not mount any different that a 3500 MK II. It all depends on it previous application. The good part about the Mk II and 670 engines is the piston cooling. We added the intercooler. I just looked at some pictures of a 7030 that I'm picking up tomorrow and noticed that the front plate does not have the hydraulic pump mounts that you need. This will be the same on a 7045. I have a bad engine that could yield a front plate if you can't find one that loose somewhere.
Edited by Calvin Schmidt - 09 Mar 2012 at 1:28pm
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 7:49pm
Calvin, I have not seen a 3500 or a 670T engine with an inline injection pump like yours. Was that in a combine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 10:23pm
Pete, The engine discription is above. I was told that the 3500 MK II engine in big loaders also had an inline pump.
