Chloride options for weight
Jim H(CO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim H(CO) Quote  Post ReplyReply Direct Link To This Post Topic: Chloride options for weight
    Posted: 09 Mar 2012 at 9:05am
Was curious what other options there are to Calcium Chloride for filling tires?  Have you tried used antifreeze or other liquids?  Thanks for the input.  Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 9:11am
Used antifreeze can be free from your local auto repair shop. Beet juice and foam are higher priced and I understand you have to cut the tires off if they are filled with foam. It won't rot the rim in 50 years though like CaCl2 does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 9:15am
Methanol alcohol and water mix works well. HTH Tracy Martin
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 9:27am
The advantage of the Calcium Chloride is the added weight.
As I recall, the proper mixture adds about 2.25 lbs per gallon.
I have heard that beet juice weighs nearly the same as the CACL2 solution.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 9:28am
I have 100 gal of Dow-Therm antifreeze from building chiller system that would also work. Anti-freeze without the additives that are used in engines . I used it in in-floor heating systems as the medium but it could be used for ballast also .
 Check with chemical companies for other non-corrosive such products.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim H(CO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 1:01pm
Thanks for the help.  Jim
