D17 SIV wide front pivot pin size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Topic: D17 SIV wide front pivot pin size?
    Posted: 05 Mar 2012 at 11:48pm
Does anyone know for sure what the front pivot pin diameter is on a D17 Series IV wide front?  Mine is badly worn and I'm going to replace it and want to make sure the size is right.  I measured 1.3" with my calipers but it was hard to measure it accurately with the front end still on the tractor.  Also - is AGCO the best place to get a replacement bushing for the casting?  Any ideas of how much they are?  Thanks!  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 7:11am
Good news Mike I found a new way to oil changed in your D17IV; but the bad news is we will need some parts to put it back together now.
I will see of I can get a true size on the pin and let you know maybe today.
Edited by Don(MO) - 06 Mar 2012 at 8:10am
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 8:28am
I think Tracy Martin can help you with a replacement pin and mabey a bushing.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 8:32am
Dave - Yep - Already been in contact with Tracy about making the pin.  We need to confirm the exact size for a D17 SIV.  I was hoping someone had measured it before to confirm what Don and I are seeing.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 9:21am
You can check, but we were able to get a new pin from AGCO several years ago and had the local machine shop weld it on.  Just make sure you use good steel if you're having it home-made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 8:04pm
Mike, Here are the part numbers for the pin and bushing.
70253386 Axle Pivot Pin
70233368 Axle Support Bushing
You might see if Acgo has them.
Don
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 8:12pm
Mike, how often do you change the oil?  I can lend you my creeper the next time if that will help to free up some time to do other things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 11:36pm
Don - we want Tracy to make a longer pin than stock to getter better pin to pushing contact.  Did you measure it at 1.3" after you got the front end out?  Let's talk later.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 5:16am
Your right Mike I forgot about that. I'll call you after lunch say around 1:30 PM today. Don
