Figured I'd show a couple pics
Mark G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark G. Quote  Post ReplyReply Direct Link To This Post Topic: Figured I'd show a couple pics
    Posted: 05 Mar 2012 at 8:55am
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 9:18am
What's the story here?  Thanks.
Dick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark G. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 9:23am
This is my 1956 Allis chalmers WD45. It did not run when I got it(the engine was seized), and I am in the middle of restoring it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark G. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 9:28am
Here is a semi-recent pic. I need to upload my recent pics yet.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 9:30am
Seems I remember your post a few months back when you were dragging it out of the woodes. Glad you got it home OK and finally the weather, circumstances are allowing you to start working on it.
Myself, I wouldn't worry too much about the charging system until you get it running and know that you don't need a different engine or if you have to rebuild this one. Also, once running you can get a fair guess of transmission, rear end, hydraulics etc. Just go through gas system making sure you have good supply of fresh clean gas. Probably a good idea to just do a rebuild of carburator. Roll engine over with hand crank to insure it's not locked up. Pull plugs and put a tablespoon of so of oil in cylinders and crank over by hand slowly with plugs removed to oil cylinders. Put a fresh battery on and leave plugs out to blow out any excess oil at this point, install new plugs and attempt to start. Oops, probably with have to at least clean points or just put in new points and condensor. Check that you have spark. Now, do the sentence on trying to start. A good fresh battery should allow you to start and run it easily long enough to determine the other mechanical conditions.
Now I see your last post. I still wouldn't worry about charging system until it's running and you can determine condition of rest of tractor.
Edited by Bob D. (La) - 05 Mar 2012 at 9:33am
Guests View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 10:01am
Good deal another one not going to scrap to end up in Red China. Keep em home!
Good luck on your restore!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark G. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 10:06am
My most recent pic.
Just down loaded my recent pics. Heres one of them.
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 10:09am
I am at a similar spot on a 59 D14 I hope to have it done by may- june time frame, and then on to the 25-40 for the summer project
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 10:09am
And a very usefull tractor to have, can be used for many things- or just for show!!
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 10:15am
I also have a 57 fourteen that has become our little "pit tractor" so to speak, its used for nearly everything
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 2:59pm
i can't wait to see some pics when your done!
There are no atheist in foxholes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark G. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 3:07pm
I will make sure to show progress and finished product pics for everone.
