allis chalmers wd45 governor
jasonTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jasonTN Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers wd45 governor
    Posted: 04 Mar 2012 at 6:27pm
i have an allis chalmers wd45 and the governor doesn't work i've had it out and the wieghts and the thrust bearing all look good but it will not respond you can move the throttle off idle and it will just keep reving up i don't see anythin wrong with the governor the weghts move free and the fork moves back and forth also if u have any idea please help thanks jason 6159694891 thanks
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 6:31pm
  IT IS OUT OF ADJUSTMENT   READ THE SERVCE MANUAL
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 9:47pm
Shorten the link between gov arm and carb. by bending it down in the middle(toward drain plug). Don't bend the up and down rod for fear of a bind in cross shaft.  MACK
