Head Gasket Instalation
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: Head Gasket Instalation
    Posted: 28 Feb 2012 at 12:53pm
ready to put head back on my WF, Do you guys install head Gasket Dry or use a gasket sealer?
Cowboy UP
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 1:29pm
Unless the gasket specifically calls for a sealer, they go on dry.
Still in use:
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 2:10pm
I always spray mine with copper or aluminum spary paint, let dry for 5-10 minutes. Don't know if necessary, however, it used to be that the gaskets came off easier when treated this way.
B26240 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 3:34pm
Blee what brand gasket do you have? victor or felpro are both ok, they have metal rings around holes for water- oil- and compression, some junk gaskets don't have  them. If its a good gasket dry is ok although I knew a old AC mechanic that sprayed his with aluminum paint as Greg sugested. head should be re-tourqued after warmup!
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:19pm
  used alum. paint for 50 y rs. will always come apart  have painted it twice an used it over
  in the 1960,s   and up
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 9:50pm
Originally posted by norm[ind norm[ind wrote:
]   used alum. paint for 50 y rs. will always come apart  have painted it twice an used it over
Cowboy UP
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 10:10pm
Another sure proof product to use is a pipe joint compound called "Blue Magic". I've used it on reasonably good old gaskets that were hard to buy any more (as well as on some new ones). On gas or diesel engines we've never had a failure or leak in 38 years. You only need a very thin film of this compound and don't get it on your clothes 'cause you'll never ever wash it out with anything.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 11:05pm
I use coppercoat spray
AGCO My Allis Gleaner Company
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 4:51am
Please don't laugh, but when we did them we used shellac. Remember this was in the 40's and 50's.
Worked well for us then. I'm certain there is better stuff available now.
Good Luck!
Bill Long
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 7:35am
At one time there was some called Gasket Shellac.
Today many head gaskets say right on them DO NOT COAT.
Dusty
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 7:41am
Something I learned many years back,probably 50's or 60's. Coat both side of head gasket with a thin coat of grease. Never had one fail so I still do it to this day.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 11:22am
These engines (unless worked) don't have particularly high compression so installing them with nothing is probably fine. Some gaskets may even instruct you to do it that way.
Having said that, I use  aluminum paint; spray one coat and let dry; spray a light second coat and install wet. Necessary? Probably not!
I originally got the idea from an old time Ford mechanic who told me this was the method Ford recommended when they started to jack up the compression on the 312 Y-Blocks.
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 11:51am
The aluminum paint sounds like a nice idea.  My father was a mechanic during the construction of the Alaska (Al-Can) highway during the war, and he used the grease method, so that is what I have done on a couple of heads.  So far, no problem, touch wood!
Lonn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 12:04pm
Has the gasket got metal on both sides? If so we used to spray them with permatex hitack. Both sides twice and let dry to a tackyness. This was how the old mechanics did it at the AC shop I worked at. Also on WD45 on down to the WC WF they also put a length of packing string in between the metal jacket on the side with the three 3/8" studs to prevent water seepage. This was done to the full length of the gasket on that one side. The D17 engines solved the problem with 7/16" studs torqued down tighter.
More modern no retorque gaskets I've left dry.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 12:52pm
yes gasket has metal on both sides, thanks for all the ideas guys!!Thumbs Up
Cowboy UP
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 12:52pm
Copper coat is what I use on most gaskets, use to use the Aluminum spray paint but the copper coat seems to work better (either spray or the dober to thin coat it) .
M Diesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Diesel Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2012 at 4:06pm
Same here. I generally use a film of anti-seize. It is important to let the head settle without binding and a little lube makes all that happen. (Sequencing alone is not thorough.) That is mostly what actually happens with the various paints.
