Question of + Ground
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Question of + Ground
    Posted: 23 Feb 2012 at 7:54am
With all the threads concerning systems with + ground, I got to thinking.  Yes, it hurts.  LOL  Seriously though, WHY did they have almost everything, back in the day, with a + ground?  Just curious.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 8:05am
Or, since everybody had pos ground, why did somebody decide to change to neg and mess things all up?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 9:44am
As I recall, Ford was negative ground and GM was positive ground. Either polarity functions so long as the loads are ignition and lamps, though ignition works better with the correct polarity and the ammeter indicates the proper charge/discharge with proper polarity. It still indicates with reversed polarity.
Thing is the generator has to be polarized by flashing when changing the battery polarity or the first time the engine runs it IS going to fry the contacts in the cutout section of the voltage regulator.
Best I can tell the polarity arguments were based on corrosion of the ground connection, but the two connections to ground, that at the starter and that from the battery will corrode in opposite directions so that argument is not great. There were great arguments between owners of underground water pipes and DC trolley operators because the direction of current would either eat holes in the pipe or add metal preserving the pipe. Again that depended on whether the pipe was close to the power substation feeding the trolley wire or distant and whether the water pipe crossed or ran parallel to the rails. If the pipe ran alongside the trolley for a long distance, one polarity would corroded the pipe near the power station, the opposite polarity would corrode the pipe at a distance and preserve the pipe near the power station. I think the auto makers based their argument on the trolley and the pipe corrosion.
The Society of Automotive Engineers, (SAE for short) for more than half a century accepted either polarity. Long about 1957 (and I posted a few times to the form a year or two ago on precise dates and standard numbers) the standard was issued saying that negative ground was preferred. And about 1960 the standard was revised saying SHALL be negative ground.
In the days before solid state, polarity wasn't a problem though radios had to have switchable polarity. A radio with the wrong polarity applied just didn't play, it wasn't destroyed. When solid state came along reverse polarity blew every transistor in the radio instantly. So polarity became more critical.
Gerald J.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 10:51am
Did the change come at the same time we went from 6V to 12V? My dad's 56 Merc was 12V. Saw a 55 Merc radio marked 6V at a junk yard. I cann't remember if either car had a + or - ground.
M Diesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Diesel Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 12:23pm
Gerald, ya left out the points argument. In the early days they lasted longer with positive ground due to the arc direction and material problems. Later on I don't think it mattered much. Wish I could find the reference.
Powering radios was definitely a vote for a positive supply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 1:39pm
I know my '54 Ford was 6 volt and I think negative ground. All the ham rigs we used were powered by military surplus dynamotors and most of those were wired for negative ground I think.
The metal moving problem with points can be and was solved by selecting different metals for the contacts swapping them for different polarity. Same as in plugs today. Same thing is true of the contact points in a vibrating voltage regulator. They can be universal or polarity specific. The reason the manufacturers want to make them polarity specific is that the metals that stand up to arcing are costly and its cheaper to build with only one good contact pad of that good material.
In ignition points there is another variable for metal erosion or transfer. That's the value of the condenser. Too big or too small will speed up metal transfer, but in opposite directions and that's surely dependent some on polarity.
Good points with the good metal on both won't be polarity sensitive but will be sensitive to a wrong value of the condenser. Cheap points with good metal on only one side will be sensitive to polarity AND the condenser value. Sometimes universal isn't universal.
In my '98 F-150 one bank has positive polarity spark, and the other has negative polarity spark so the factory plugs have platinum only on the center for one bank and only on the grounded electrode for the other bank. Saves pennies, but they only sell plugs with platinum on both electrodes for replacement.
Gerald J.
Mike_426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike_426 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 7:57am
I had my d17 battery hooked up backwards for a coupler hours of runtime till I read my manual and it didn't seem to harm anything just the amp meter was reading funny... ? ? Now its hooked up right and all is well.. I think .
G, 200, 8050 mfd, D17, 195 chainsaw, c-wide front
EdK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 9:49am
I think that the positive ground theory comes from the fact that current is the flow of electrons through a wire. Electrons are negatively charged, and flow from the negative terminal to the positive terminal, thus the flow from, (the inlet pipe), the flow to, (the bucket), is logical. Electrically it makes no difference as long as everyone follows the same standard. Being an old transistor engineer, we could have designed everything to the positive ground standard, but when the semiconductor was developed the de-facto standard was negative ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 10:09am
GM was Neg (-) ground on both 6 and 12 V systems . Ford used the Pos (+) ground up to the time they switched to 12 V. My 66 White truck uses (+) ground also with a Leis Nevill alternator.
 Most European (English) vehicles were also (+) earth as it was thought to be the proper direction of electrical flow. (all my British motorcycles are (+) ground.
Cape Cod Bob is correct, let us remember that the negative electrons travel on the surface of the conducter, therefore the exclusive use of stranded wire for DC applications is necessary for flow. never use solid wire on your vehicle. Just thought I'd throw that in.......cause I'm taking a break from rewiring a guys hotrod that was wired with 12/2 ROMEX a contractor left behind when he rewired the guys house.
Cape Cod Bob
You do have a few things mixed up. Yes electrons move from negative to positive. This is not a theory it is a known fact. It is also known that opposites attract. To get a better understanding of why a negative ground system was chosen we need to look at the molecular level.
In an atom there are three parts:neutron,proton, and electron. The electron orbits the nucleus(protons and neutrons). The property or willingness of an atom to give their electrons ultimately determines the materials conductivity(way more to it than that; this is a simple description). By natural law materials are or tend to stabilize in an equal state(once again there are exceptions and I'm just generalizing). We know that an atom has an equal number of protons and electrons. Therefore an atom doesn't have a charge. Another important property we need to know about atoms is that they can gain or lose electrons and stay the same chemical makeup(ie copper is copper even when it is an ion) When an atom gives or gains an electron it becomes an ion and can be considered to have a charge.(This is important). The movement of these electrons is what creates a charge or difference/potential. The movement of these electrons is electricity! If the electrons flow in a uniform direction we have a current. That is a lay description of what electricity is.
Oops, I forgot to mention that an atom doesn't give up protons. When you figure out how to do this let me know. I've got a lot of lead that needs changed into gold big smile
Anyways, back to electricity. Since we have addressed the molecular level lets get some vernacular out of the way. Voltage is the potential of electron flow. When you have a battery sitting on a shelf not in a circuit it is said to have 12 volts. Think of this statement as there is a difference of electrons equal to 12 volts. Or there is a potential of electrons to flow from the negative side to the positive side(greater the potential the greater the voltage). This is important when you try to justify a 1 foot section of wiring during a voltage drop test. When we perform a voltage drop we measure a voltage. If there is a resistance we will see a voltage(for example maybe 1 or 2 volts). But wait! How can a piece of wire create a voltage?!! Only batteries or generators and stuff can do that right? Wrong! Voltage is not something we create it is a measurement of potential Smilie Now, the easiest property of electricity to define is current(in lay terms). Current is the amount of electrons flowing(quantity).
Also, it is important to understand how a battery works. The chemical reaction of the lead plates(calcium, antimony, and lead) and sulfuric acid creates a solution of ions. These ions donate their electrons and that is where the original electricity starts. Without the chemical process there would be no potential flow of electrons(voltage). It is not just electrons flowing from a negative plate to a positive plate. It is the gaining and losing of electrons of the plate. When a battery discharges the chemical process sulfates the plates(plates lose electrons). When a battery is charged the chemical process is the reverse and oxides the plates(electrons are gained).
Ok who is lost? Confused
Alright so you are asking yourself what does this have to do with negative and positive ground systems. Quite simply it is a matter of effort. Every conductor in that vehicle that connects to ground essential becomes eligible to give up electrons.There is a potential huge imbalance of negative ions. Another way to comprehend what I am saying is to think of a negative ground system as allowing a chassis to be an amplifier. This is also the bane of negative ground systems! In a positive system the positive side will receive the electrons. Therefore only the negative feed wires will be donating the electrons on the current side of the load. This requires larger wires when a large amperage is required(this is true in ground systems but Im referring more to the momentary jumps like ignition coils and injectors). Therefore a positive system in essence will require better quality components. So, from a manufacturers stand point it is a lot cheaper to go negative. Also, standardizing the system played an important role in the decision. When computers came along it pretty much sealed the deal for negative ground systems in autos.
Ultimately it comes down to the fact that: negative ground immitates natural electrical flow, the industry needed a standard, and it can be cheaper formanufacturers. There is way more theory behind it,
Edited by Coke-in-MN - 24 Feb 2012 at 10:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 10:42am
Its AC and RF that travels near the the surface. The dept if current (skin effect) is shallower the higher the frequency. DC travels throughout the conductor no matter how large. Stranded wire is used in vehicles because its flexible and doesn't break so quick from vibration and flexing. Unless its been soldered and the solder has wicked up the strands to make it solid. Then stranded wire will break at the end of the solder.
Solid state electronics is polarity sensitive. Tubes are too, but are not destroyed by reversed polarity, they just don't function. Transistors and ICs are usually destroyed instantly. DC motors with wound fields whether series or shunt fields run the same direction with either polarity. DC generators are shunt wound and build voltage according to the residual magnetism so have to be flashed before running with reversed battery. DC ammeters usefully indicate direction of the "conventional" current flow showing energy to the battery on the charge side and energy out of the battery on the discharge (or minus) side.
Ben Franklin set the standard for DC polarity with + being the carbon rod of a LeClanche cell. He had two choices, he guessed wrong, but we continue to compute currents as if he was right though we understand current to be motion of negatively charged electrons these days. Trying to match up electron motion to circuit computation will cause brain fatigue and maybe brain or circuit damage.
Gerald J.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 10:59am
I was taught both in school, electron theory and conventional theory but I liked the way he said that electrons go from negative to positive so I believed him.  LOL
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 12:41pm
It's a good thing that I don't have understand all that to drive a car.
I have two tractors both 6 volt  + ground and I NEVER have to clean the battery cables.  Now if my memory serves me from my days on the farm in the 50's and 60's I swear that I have cleaned corosion off the + ground tractors????
Dennis
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 1:37pm
Teacher Coke, you talk about copper ions being given off copper wire... Then in theory if you have an electrified electric fence thats charged at 15KV and  you crawl under it in the pouring rain and got both knees and hands  down in the wet grass while soaked to the bone, and electric fence wire is galvanized, Do the galvanized ions go trough your body or do they go around your body or is it just 15KV of human ions leave your body when you happen to get to close and the electricity jumps from wire to wet back?  I couldn't tell if any ions moved in the millie second of snap, All I know is it'll flatten you face first in the mud...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 1:53pm
Good Lord Coke, I wanted to learn something, not an education.  LOL
Marvelous way to teach and old fart new tricks.
Thanks, its been a pleasure.  Remind me to never ask you way when you ground a ....  LOL
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 3:41pm
I'm positively cornfused. I guess I look negitively at certain things?????
Oh well, I won't do that again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 5:58pm
The one thing you have to remember about all this high falootin' physics talk is that it's being said by the same bunch of guys(scientists) that have PROVEN that bumblebees cannot fly !
By the way, what happened to the '36' volt cars that were supposed to be coming out 3-5 years ago? I got a whack of special interface chips I R&D for the 'new' car electrical systems sitting here collecting dust.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 9:28pm
I just found a article and read it and posted it , so if it's to deep or wrong then guess I goofed but i thought the theory and ideas from the article were something to think on.
 Like i said the British motorcycles I have are all + ground and those English drive on wrong side of road , or is it right side ???
 Like Brian Reese wrote me back when I questioned his video or riding bike , I said he went around round-about the wrong way , his answer was if he went the other way he would have been going home rather than for a ride ..
