Front stack weight???
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: Front stack weight???
    Posted: 22 Feb 2012 at 8:51am
My grand father found this along the side of the road, does any one know what it goes to? Are they AC?
Edited by Josh Day - 22 Feb 2012 at 8:51am
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 9:46am
   Does it have a part number on it ? Most AC weight numbers start with an "AM" prefix. How big are they (length, width, thickness, weight) ?
http://www.rumelyallis.com
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 10:47am
Looks like the weights used to balance an elevator car?
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 10:53am
I've seen those before. I wonder if it's off a "uni-system"combine. We have a dealership down the road that sold them and still has quite a few units and piles of parts.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 5:46pm
Does not look like any Allis or New Idea weights that i have ever seen.
The universal answer to all questions is yes, how much do you want to spend?
podunkpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote podunkpuller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 5:55pm
Definitly not an elevator counterweight. We just take 1 inch steel plates and order them to the dimesion of the frame as needed. We don't bother painting them or rounding off the edges. Once in place and the evevator is balanced they are never handled or messed with again. How ever the overage does then become pulling weights here in podunk!!!! The weight of steel is .28 lbs per square inch, lead is .48 lbs per square inch, but in my case the steel is free!
310, 2 B's, C, 2 WC's, 2 WD's, WD-45,D-14, D-17 gas, D-17 d IV, 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 9:25pm
the only num. I can find is 36250 or 36850 I can't tell on the 2 or 8 for shure, it's about 16'' long and 6.25'' wide and 3'' thick, mabey 50-60lbs.
