7020 Hydraulics??
MN_M2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MN_M2 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Hydraulics??
    Posted: 20 Feb 2012 at 8:26am
I've been looking at newer sprayers and so many have hydraulic motors that run the sprayer pump and I'm wondering if a 7020 will handle that.  From what I've seen the pump would require 11-12gpm @ 2000psi max and the boom control (raise, lower, fold)would require 3gpm @ 2200psi.  For what I would be doing I would not need the max volume & pressure out of the sprayer pump so I should be able to reduce the hydraulic flow on the tractor to maybe half and I can run a low pressure return back to the tractor to help reduce back pressure restriction.  Basically I would using both tractor remotes continuous while spraying, I don't want to overheat the hydraulic system and damage something.  Anyone else running something similar or know if this will work ok?
Thanks,
Chad
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2012 at 10:33am
Should do it.  Dad runs a Hiniker air blower with his 7060.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2012 at 10:15pm
Control the volum with the controles under the seat. Don't use a flow control on the motor.  MACK
