D17 IV Remotes Lever Hookup Question
AllisUpstate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Topic: D17 IV Remotes Lever Hookup Question
    Posted: 19 Feb 2012 at 10:55am
I added a second remote to my D17IV.  I forgot to pay attention to the positions of the rods connecting the levers back to the spool valves.  The control levers have two holes, one below and one above their pivots.  I connected all three rods to the lower holes.  The lift arm is correct, as it works properly by raising the lift when pulled back.  I put the two remotes rods in the lower holes, but when I look closely at pictures in the operators or shop manual, these two rods appear to belong in the upper hole above the pivot.  This would of course exactly reverse the way the remotes work, including the float position.  I don't have any double acting remote cylinders to check it with right now, so I was wondering if anyone could confirm whether these rods should go into the lever holes above, or below their pivot points?
Thanks.
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 11:46am
The float position is opposite on the spool for the remote vs the lift valve. You would want the rods connected to the top side of the lever so when the lever is pushed all the way forward it can go into the float position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 2:36pm
Travis,
Thanks!  That did the trick.  I can feel the detent position now on the remotes levers.  Next time I'll remember to take notes or a picture before I take something apart.
